Dirty Word.
I was coming down a section of 17 in Virginia that is only two lane, had to pull off the road for fuel, getting back on I hit "something" that turned out to be decorative boulders placed around a driveway.
I immediately pulled off on the other side of the road, looking frantically for damage thinking Oh
how much will a new side panel and wheel well cost?
Couldn't see any damage anywhere. Then I noticed the steps looked a little wonky - and lo and behold they'd been boinked toward the rear about half an inch - they work, but scrape. So should I attack them with a sledge hammer or otherwise try to bend them straight? Or will that cause the bolts to fail? Better to replace?
OH, and then the BIGGER thing that I noticed two weeks LATER. I was checking my air pressure and my curbside front tire only had 24 lbs in it - YIKES. So of course I got out the little battery operated compresser and let it fill forever - finally gave up when it reached 60 lbs. Said
and pulled off the air hose to hear the ssssssssssssssssss of escaping air. Changed out the tire with my spare, a sweaty proposition in 90 degree weather, and fanagled the tire up into the bed of my truck to take it to the garage and get it plugged. Today I decided to soap it at home and find the leak myself. As I flipped it over I saw the problem, the rim was completely bent in on the inside of the tire. In fact, the aluminum is actually cracked. I don't know how it held ANY air, and it may be a testimony to my Reese Dual Cam that I drove it home over 100 miles without realizing that there was anything wrong. Lucky it didn't shred and eat the wheel well. I just noticed that it did look a bit squishy a few days ago. These tires are the OEM Goodyear Marathons, manufactured 12/05 so I was planning to replace them in the spring. They have plenty of tread left and only the one that's on the bad rim has any sidewall scuffing or other apparent wear.
I'm debating whether to replace all four - I'm going with Marathons again - or just this one -with the sidewall scuff and 100 miles underinflated, I'm thinking it would be prudent to replace this one rather than mount it on a new rim and pray. (I know, I know all of the Marathon horror stories. I check mine every time I go out and they all look good. I travel a bit, I'm not putting 5K per year on them so I can't see going for Michelins. )
So where can I get a new matching rim without breaking the bank? These are standard 06 Safari SE rims.
Oh by the way, I always MEAN to check the air in the spare ... but it's one of those "I'll do it next time" items all too often. I had 33 lbs so I got to sit 15 minutes in my truck letting the itty bitty compresser fill it up. YES DEARS I DID CHECK the back side of the rear rim - and oh ....... I laid down right on an ANTS nest to do it!
Paula
