Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Steps
Old 03-11-2004, 07:14 AM   #1
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
Lower door step
I noticed the Ambassador that Phaedrus listed for sale in another thread has two steps leading up to the door. His top step looks exactly like the top step on my Overlander. At six feet tall, it did not occur to me I may be missing a step, but it probably has to my 5'4" wife
It appears the second step is rigid, and does not fold up with the top step. It must slide into the two square holes on the top step. Is this accurate?
Does anyone have a closeup picture and/or general dimensions of the second step? Is there any reason I should not build a replacement step?
Tom
Phaedrus's image appears below:
Old 03-11-2004, 07:24 AM   #2
Chuck
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
The second step was an option. it folds, or actually, flips over to sit on top of the first step. I have a diagram in my service manual, but I don't have it right here handy.
The PO of my trailer gave me a reinforcing bar, that looks like it may have been home-made. its just a metal rod, about 3' in length, with a couple of angles welded on the ends (looks like a capitol "I"). this is used as a brace behind the lower step; one end cradles the back of the step, and the other is simply jambed against the trailers frame. without this, the lower step is not very stable. However, I see no mention of this part in the diagram in the service manual. I'm wondering if the lower step is missing some part that makes it rigid, or if its just a poor design, or what.
Old 03-11-2004, 08:13 AM   #3
wb13798
wb13798's Avatar
Profile:  2004 28' Classic
huntsville , Alabama
i had the same problem . "poor design"
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 trailer
PEGGY SUE security dog
wb13798 is offline   Reply With Quote
Old 03-11-2004, 08:17 AM   #4
smily
"Still Working"
smily's Avatar
Profile:  North Charleston , South Carolina
been there
you can see all you want on steps fro an Airstream at this link
http://www.airforums.com/forum...ep+replacement
Name:	pictures from camera 023.jpg
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
smily is offline   Reply With Quote
Old 03-11-2004, 09:19 AM   #5
Chuck
Chuck's Avatar
Images: 99
Hmm.. I wonder if I'm missing a piece? my lower step will swing back and forth like a pendulum without that "accessory" that I mentioned. I'll have to take a closer look. The vertical support from which the lower step hangs from the top step: there's nothing in its way to prevent it from swinging in toward the trailer.
the other problem with them is that when they're retracted for traveling, the latch that holds them up is not very secure. doesn't take much of a bump for them to drop down. so some PO installed this rinky-dink external hasps that dont' hold very well, either, but they help...and they rust, too. I'll have to take a closer look and compare with your pics.
Old 03-11-2004, 10:01 AM   #6
smily
"Still Working"
smily's Avatar
Piece
That piece you refer to is an aftermarket part.
You can often find them at Airstream Flea Markets for around 5 bucks a set.
If you cant find one, you can make a set out of flat 1/4" aluminum
It is very easy to do. I will try to post photos of a set tomorrow.
I have installed them on Airstreams before. They work great and they are a cheap fix.
Smily
Ken Smillie
Old 03-11-2004, 10:34 AM   #7
smily
"Still Working"
smily's Avatar
Stiffener
This is a little rough but you can see how it is made.
The cut out at trhe top is to accomdate the "rib" that runs down the middle of the step (underneath)
Smily
Ken Smillie
Old 03-11-2004, 10:50 AM   #8
Chuck
Chuck's Avatar
Images: 99
So...the factory intended the lower step to be able to swing back and forth like that, by NOT including a part such as this?
Old 03-11-2004, 11:08 AM   #9
smily
"Still Working"
smily's Avatar
Not quite
The upper step is notched to allow the "down arm" to sit aginst the upper step. This "Slot" wears over years of repeated use and it gets a little sloppy.
I cannot say for certain that AS never resolved the problematic wearing of the steps. They may have.
I just know that these devices are common as an aftermarket product.
Smily
Ken Smillie
Old 03-11-2004, 11:13 AM   #10
smily
"Still Working"
smily's Avatar
Stiff rod
I went back and read your ealier post a little more carefully. I have seen the stiff arm assembly that you refer to.
It is very practical but I believe it is not stationary. Do you have to remove it each time you close your steps?
Whereas the piece I described is a permanent fix and you dont have to fool with it once installed.
Smily
Ken Smillie
Old 03-11-2004, 11:34 AM   #11
Chuck
Chuck's Avatar
Images: 99
yeah, its just a 3' long metal stick, with a couple of cross pieces on the ends that stabilize it. I store it by sliding it into the space that the pull-out table slides into when its stowed. so when I'm setting up camp, if the second step is needed, I can just reach inside the door and grab it.
I'll see if I can concoct a diagram. don't have any pictures of it.
Old 03-11-2004, 12:04 PM   #12
Chuck
Chuck's Avatar
Images: 99
Ok, pardon the crudeness of my drawing.
step on this thing without any support, and you'll likely break your neck.
Old 03-11-2004, 12:08 PM   #13
Chuck
Chuck's Avatar
Images: 99
The solution is simply jamming this rod in place. The angle iron welded on each end fits snugly against the frame and the floor, and on the other end, fits along the top rear edge of the lower step, and prevents it from sliding backward when someone steps on the step. without it, you'd likely lose your balance when that step starts moving, fall, and break your neck.
Old 03-12-2004, 05:02 AM   #14
TomW
TomW's Avatar
Normal , Alabama
Images: 77
Different in the sixties?
I appreciate all the responses, and I would really like to have a set of steps like smily's, but my top step does not appear to be compatible with the bottom steps discussed so far.
It does not appear that my step ever had any linkages pinned on the sides. Does anyone have a top step that looks like this composite image, AND a lower step?
Tom
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
