Old 05-16-2013, 02:53 PM   #1
Airstream fanatic
Grapes's Avatar
Bouse , Arizona
i feel dumb for asking...but....
How the heck does my steps come out on my 79'??? I've tried to wiggle, wobble, and even pull down on the lever... its not working help?
Cass
1979 Sovereign International (Olivia)
1986 F-250 4X4 (Oscar)
BLOG: http://grapesbigadventure.wordpress.com.
Grapes is offline   Reply With Quote
Old 05-16-2013, 02:56 PM   #2
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
The steps should release and drop by gravity alone, but can get gobbered up, rusted, and bent.
Pull the release handles or trim piece (I don't know what you have), While at the same time someone pulls down on the front lip. You should have some movement. If you can get it open a little, hit the hinge points with some PBlaster.
Once down, clean it up and lube it.
Good luck!
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The ďOhio Airstreamer -- Informal forum for weekend campingĒ thread.
DanB is offline   Reply With Quote
Old 05-16-2013, 03:04 PM   #3
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
Have you gotten down and looked up under the steps to see what is going on there?
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 05-16-2013, 03:39 PM   #4
Airstream fanatic
Grapes's Avatar
Bouse , Arizona
I'll make hubby do that... I imagine its just stuck. I can push down on the lever thingy and the step pops off the latch, but I can't figure out how to pull it out
Cass
Old 05-16-2013, 06:29 PM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
The steps are just playing dead until you get your fingers close enough for them to get one.
Wear gloves. Leather gloves. Spray some Silcone lubricant on both edges of the steps where the levers are. In theory you move the levers and the steps drop down so that you can unflold them. You might try banging on them at each end with a rubber mallet or hammer handle and pulling and working to see if they come loose. If you get them to drop down then spray everything with Silicone again and unfold the steps.
Bill M. is online now   Reply With Quote
Old 05-16-2013, 06:31 PM   #6
DanielB's Avatar
My go-to tool in situations like that is the sledge hammer.
- Andrew Carnegie
Old 05-16-2013, 06:31 PM   #7
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
If the step moves a little, try squirting WD40 on both sides up inside where the step guides run in the supporting frame member. That should free it up. Then grab the lower part of the step that hangs down under the trailer and gently pull down and forward while depressing the release mechanism.
DryFly is offline   Reply With Quote
