Old 10-27-2014, 05:22 PM   #1
bellastream's Avatar
1969 31' Sovereign
Auburn , Washington
Help with front steps '69 Sovereign Intl.
I am repairing the front step frame and outriggers I can't figure out what holds the step in the up position. Any help or pictures of the mechanism would be greatly appreciated.
bellastream is offline   Reply With Quote
Old 10-27-2014, 05:48 PM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
On a 68 there is a piece of metal with a handle formed into it that spans between the two sides. It is right under the door frame. When the steps go up, it holds them up. You pull out, the metal flexes, and the steps drop down. Looks to me like that piece on your steps has rusted off. I can send you a pic if you would like. 69 steps may be different so let's see what others share, but the steps look the same as my 68. I don't really have any idea on how to fix it.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 10-27-2014, 05:49 PM   #3
1969 31' Sovereign
Auburn , Washington
Pictures would be great and where would I be able to find these parts.
Old 10-27-2014, 08:52 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
It appears you are missing the latch assembly. There should be a handle on the right side of the step.
This handle is spring loaded. At the back of the slot on each outrigger there should be a latch which is operated by said handle mechanism.
When you raise the step up to the store position. The pin on each rear arm (which slides in the slot) snaps behind the latch on each side.
You press down on the release handle which rotates the latch assembly and the step drops down.
At the back of each slot there should be a latch. Kinda looks like the trigger on a gun. There should also be a casting or square shaft just below the floor. Which connects each side of the latch to the release handle.
Old 10-28-2014, 11:15 AM   #5
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
The latch/catch is missing. It is a hinged metal bar across the top that has tabs/handles on both ends to lift in order to let the steps down or stow them for travel.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-28-2014, 12:57 PM   #6
65will
65will's Avatar
1969 25' Tradewind
Greenwich , New York
metal missing
Hello
On the my 69 there is a strip of metal ( spring Steel) above the step this has the catch in it. I am not home right now,or I would send you a picture. If you want to pm me I will get taht to you later.
65will is offline   Reply With Quote
Old 10-28-2014, 03:25 PM   #7
65will
65will's Avatar
1969 25' Tradewind
pictures of latch
Hello
I took a couple of pictures of the latch. hope this helps
Old 10-28-2014, 04:22 PM   #8
68 TWind's Avatar
1968 24' Tradewind
Bellastream,
Just got home and checked forum. The pic 65will posted shows that his step look just like the steps on my 68. The top piece with the finger grip is springy. When you pull it out the steps drop down. If you notice there is a thin slot cut int the top of the part which allows the handle to pull out just a little. It does take a good tug on the top part to get the steps to drop (my wife always has trouble). But, it is a very positive hold and I've never had the steps drop down on their own.
If you do need more pics send me a PM and I'll email some to you as I always have trouble posting pics.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 10-28-2014, 08:16 PM   #9
1969 31' Sovereign
Auburn , Washington
Thank you all so much I will be able to make that piece no problem I will be Shure to take lots of pictures.
sovereign
What did the '77 31' Sovereign Intl LI Pets 1974 - 1979 Sovereign 5 10-15-2015 02:55 AM
Need plans to rebuild front double bed couch in 69 intl Kgestring General Interior Topics 0 06-03-2012 05:28 PM
New to Forum and own a '68? Sovereign Intl Land Yacht ? Bart_I308J 1965-1969 Sovereign 28 12-24-2011 05:54 PM
about to pull trigger '74 Sovereign Intl patis General Repair Forum 18 03-08-2010 02:32 PM
1979 Sovereign Intl. Roof Damage? Dakota's Dad General Repair Forum 2 07-04-2009 10:52 PM
