Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Steps
Old 06-22-2008, 04:01 PM   #1
kamadeca
kamadeca's Avatar
Profile:  2003 25' Safari
Burlington , ON
Help! Need a measurement
Hi folks, not sure this is where this question belongs, but here goes.
We are about to move our Silver Condo to a seasonal site and I would like to build a deck beside the trailer. Ideally I would like to have the deck about 7-8" below the door to form a "step". My question is how far off the ground is the bottom of the door? I would measure my own, but the ground isn't level where we have the trailer now. By the way it is a 2003 Safari 25 SS.
Thanks in advance for your help as always.
Regards,
Malcolm & Katalin
2003 Safari SS
WBCCI # 12523
kamadeca is offline   Reply With Quote
Old 06-22-2008, 04:27 PM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Regards,
Best you measure your trailer.
Your trailer is equipped with torsion axles. Depending on how much the trailer was/was not used, the dimension your seeking can vary by 2 to 3 inches.
Once you have the trailer into it's new home, you must , in order to protect the axles, place the trailer on some jack stands so that you remove most of the weight off the tires.
The jack stands are not intended for that purpose. They will break if you try to lift the trailer.
Keeping most of the weight off of torsion axles, when not in use for an extended period of time, will appreciably extend their life.
The reverse is true, if you do not remove most of the weight.
Using the jack stands, will further alter the dimension that you seek.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 06-22-2008, 04:30 PM   #3
easyride
Profile:  1977 27' Overlander
naples , Florida
Seems like it would be a lot easier to level & block trailer,then proceed to build deck,that way you`re now belly crawling to get to blocks and stabalizers. Just my opinion. Dave
easyride is offline   Reply With Quote
bed measurement help ALANSD General Interior Topics 6 03-06-2008 01:08 PM
Help - need a measurement kamadeca Cabinets, Counter Tops & Furnishings 2 11-17-2007 04:08 PM
66 caravel measurement tonyg 1966-68 Caravel 1 06-19-2006 09:40 PM
Need measurement jgump General Interior Topics 0 10-30-2004 12:20 PM
What length do I use for a campground measurement? TBKP's Overlander On The Road... 7 02-10-2004 07:49 AM
