Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Steps
Old 07-30-2002, 07:34 AM   #1
JohnGalt48
JohnGalt48's Avatar
Profile:  1977 31' Sovereign
folding step trouble...
Hello everyone!
I'm new to this forum and sorta new to Airstreams...I've got a pretty nice '77 31 ft. rear bath twin Sovereign that I bought about 4 years ago, and now I'm finally starting to actually use it! I've developed a problem with the folding step...it seems that one side won't "lock" in the open position anymore. It looks like the "tang" cut into the metal beam of the trailer has perhaps worn and won't engage the step mechanism anymore. Has anyone had this problem and come up with a fix for it?
Thanks for any help.....
JohnGalt48 is offline   Reply With Quote
Old 07-30-2002, 09:56 AM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
You can replace the footstep outriggers or, add some weld to the worn area, and carefully file a new slot. Make sure however, that the step has not been tweaked out of alignment by being hit or bent.
inlandrv.com
airstreamparts.com
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 08-15-2002, 08:13 PM   #3
Diesel Dude
Profile:
I have the same problem on my '76 22' Globe Trotter. What are 'outriggers'??? I don't really want to try welding this.
Diesel Dude
Diesel Dude is offline   Reply With Quote
Old 08-16-2002, 08:31 AM   #4
JohnGalt48
JohnGalt48's Avatar
The welding was easy....a buddy came over with his portable 110v wire welder and added just a bit of weld to both sides...took about 5 minutes...a tiny bit of filing with a rat tail file and it's as good as new. I also lubricated the slide area this time with some wheel bearing grease. Works perfect...
JG
Old 08-16-2002, 01:11 PM   #5
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
JG,
My step is in good shape but I decided to keep it tucked under the trailer and use an aluminum step from Camping World which has a wider area. It has worked fine so far and is easy to pick up and throw in the trailer when packing up.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Lower door step TomW Steps 31 01-17-2005 02:45 PM
Step repair took 3 hours--Airstream paid Kistler Our Community 8 11-12-2004 09:09 AM
Need a step? jcanavera 2001 Safari 8 01-26-2003 12:05 PM
Handy hitch step Pahaska Our Community 0 06-26-2002 06:44 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 03:35 PM
