Old 03-18-2019, 10:15 AM   #1
the ponz's Avatar
Detroit , Michigan
entrance step hardware failure: one must know how to fall
1986 Sovereign.
Please tell me I am not the first guy who had to fix this.
I have looked through quality posts concerning the replacing and repairing of entrance steps. Unless someone here convinces me otherwise, I believe my best option is to replace the entire unit with a newer style of steps. The steps and braces themselves are serviceable. It is the highly specialized fasteners that have rusted and failed. Any recommendations from personal experience is welcome.
That is if I can get the old ones off the camper. Before I cut the bolts which hold the step in the race cut in the outriggers, I am soliciting suggestions.
86' 31' Sovereign
the ponz is offline   Reply With Quote
Old 03-18-2019, 10:51 AM   #2
1994 34' Excella
Warren , Manitoba
Go to Out of Doors mart website and order the required repair parts. Easy fix, and I believe ther is a video on the repair as well.
WBCCI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 03-18-2019, 10:57 AM   #3
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
I would rebuild them if at all possible
Depending on how your trailer sits you may just do away with the first step. That's how we run ours and our trailer is higher then most with fresh 32 degree axles
AlinCal is offline   Reply With Quote
Old 03-18-2019, 11:05 AM   #4
the ponz's Avatar
Detroit , Michigan
Thanks for the replies.
So I looked at the Out of Doors parts page and found the necessary hardware.
Cost to replace all hardware, $292.40 for 16 points of contact.
Has anyone found a more reasonable solution? I will be visiting my favorite hardware store later today.
86' 31' Sovereign
Old 03-18-2019, 11:10 AM   #5
AlinCal's Avatar
1991 25' Excella
It's all specialized hardware. You will not find it elsewhere but if you do let us know. 👍
Old 03-18-2019, 11:21 AM   #6
the ponz's Avatar
Detroit , Michigan
I was incorrect earlier: total cost $226.64
86' 31' Sovereign
Old 03-18-2019, 11:28 AM   #7
Mollysdad's Avatar
I thought those were the newer style steps!
I have a 2017 and have those steps.
However, I leave them folded up, just lower the first step, and use a folding step on the ground. It's super sturdy, and big. For my bad knees, it's easier and safer.
When I pack up, the step just goes inside the door, upside down.
Old 03-18-2019, 11:38 AM   #8
the ponz's Avatar
Detroit , Michigan
The lower step was not deployed when the failure occurred. The hardware which holds the support arm to the upper step failed. After I picked myself up, I noticed that every attaching point was severely corroded after over 30 years of service.
I have faithfully serviced this Airstream in my 15 years of ownership, but I certainly neglected to look at those fasteners. I'm just glad it was me on the step when it failed and not my wife.
86' 31' Sovereign
Old 03-18-2019, 11:51 AM   #9
1994 34' Excella
Warren , Manitoba
That is probably one of the least expensive repairs on an Airstream. I have rebuilt mine and it is worth every penny to have good steps. I lubricate with spray silicone several times a year.
WBCCI #7394
Old 03-18-2019, 12:45 PM   #10
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Someone had replaced one of the bolts holding the steps to the outrigger on my trailer with a standard hex head bolt. Over time the nut loosened and the bolt wallowed out the end of the slot in the outrigger such that it would no longer hold. Following the suggestion of a repair post I found on here I ground out the end of the slot a little and bought the replacement part at the Salem rally from the Airstream booth. IIRC it was around $4. I had to bend out the bottom of the slot where it changed directions into the lock position to get the shoulder head bolt in and then beat it back into place.
I didn't go to the ODM web page, but an alternative might be found here:
https://www.mcmaster.com/shoulder-screws.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 03-18-2019, 12:45 PM   #11
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
You would be foolish to remove those steps!
The hardware is spendy, but with maintenance, those steps will outlive anything else. A little silicone goes a very long way!
AtomicNo13 is online now   Reply With Quote
Old 03-18-2019, 05:10 PM   #12
the ponz's Avatar
Detroit , Michigan
Every Spring, I repack the wheel bearings and service every spinning, sliding, pivoting and oscillating part I can get too, including the steps. Foolishly, it never occurred to me to get down and inspect the nuts and bolts that over time, simply deteriorated to the point of failure.
86' 31' Sovereign
Old 03-18-2019, 05:27 PM   #13
1994 34' Excella
Warren , Manitoba
I never gave much attention to the steps either, until they failed like yours did. Now they get regular lubrication. Probably one of the most used and least looked after parts on the trailer. PITA to repair, but not as costly as some parts are!!
WBCCI #7394
Old 03-19-2019, 09:42 AM   #14
barefootmom's Avatar
2004 34' Classic S/O
Riverside , California
We do the same. Shortly after purchasing our 1998 30’ Excella, the bottom step hinge failed. One part was almost $200! I find it so much easier to pull the first step down and use the same step stool. Much less complicated to unfold, too!
barefootmom is offline   Reply With Quote
Bent entrance step aemers22 On The Road... 2 07-06-2017 07:03 AM
I know one of you will know how to... AIR-Quarius Cleaning, Stripping & Polishing 1 05-31-2014 10:45 PM
Argosy entrance step argosyman Steps 4 04-28-2011 08:52 AM
drop down entrance step repair jasper2222 Steps 16 05-31-2005 11:24 AM
Entrance door hardware 72 Overlander 1 Doors & Locks 7 01-14-2004 07:17 PM
