Old 03-19-2019, 09:52 AM   #15
Fit
Fit's Avatar
2018 25' International
Ottawa , Ontario
I had the same exact problem on our first summer with our 2018 Int Serenity. Contacted Can-AM where we bought it and they sent me new parts. In my case the bolt sheered right off. It was a quick fix.
Good Luck
Fit is offline   Reply With Quote
Old 03-19-2019, 09:57 AM   #16
Annapolis , Maryland
Periodic maintenance
My steps have frozen twice. Iíve learned to disassemble and lubricate the joints every six months.
rhpeahl is offline   Reply With Quote
Old 03-19-2019, 12:19 PM   #17
1976 31' Sovereign
Helotes , Texas
I just finished reworking my steps. I spent over $200 in new hardware from Out of Doors. I had 10 bolts that were rusted in place so bad (even after using PB Blaster every day for over two weeks) that some broke off and some refuse to cooperate in any way. I ended up drilling out the 10 and had to re-tap the holes with a 3/8" -16 tap. Not an easy task and not for the impatient!
I ended up burning through over $100 in drill bits (Yes, you read that right!). When it was all done, after over a month of work, I began to think that $650 price tag for a new one was no so bad...
Greg
glrtex is offline   Reply With Quote
Old 03-19-2019, 12:34 PM   #18
2017 27' International
Galt , California
entrance step hardware failure
For the life of me (almost literally), I do not understand why Airstream continues to use this step on their higher end trailers. My 2001 Excella had this step (as does my new International). After about 10 years in, the steel out riggers failed. The "Nike" swoop "swoped". That is to say the the hook at the end of the slot rounded over. At least twice, I almost took a tumble when the catch failed as I was going up. If I remember, I took mine apart by unscrewing the posts that ride in the slots (one was loose anyway). The rest of the bolts are hex head. I bought the out riggers from Airstream and they were reasonable. The labor to replace them on the other hand, was about $1800 (all labor). On my new trailer, I have a custom manufactured bracket that a fellow Airstreamer loaned me that rests against the frame and body, and hooks over the back of the lower step. This takes the fulcrum weight off the lower step and saves wear and tear on the step, and possibly your booty. This unit is shaped like an "H" with a welded steel angle iron on one end for the step, and a bolt welded to a piece of round bar. the bolt is adjustable within the longitudinal rod for length, and the round bar engages the joint between frame and lower body panel. This takes all the spring out of that lower step,
Andrew, K6STN
2017 27" FB International Signature
2017 F-250 Lariat 4x4 diesel crew cab
absteen is offline   Reply With Quote
Old 03-19-2019, 01:22 PM   #19
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
I was getting impatient with my steps, and tried to find some better replacements. All of the aftermarket steps that I found were much larger, and really wouldn't have fit as nice as the originals. So I lubed 'em up, and try to use them as little as possible. I have a pair of plywood boxes that I built that nest inside each other that are the primary steps. I can't say that this is a perfect solution, as they are kinda flexy, and sometimes rock on uneven ground. I had one of those folding steps things like Mollysdad has, but mine wasn't as nice and a friend went ass-over-teakettle after a camper-lubrication session, so into the trash it went.
It seems like those fastener things that the steps hinge on can be replaced, or if the hole in the arm is out of round or broken, it could be TIG welded?
SuzyHomemakr is online now   Reply With Quote
Old 03-19-2019, 05:38 PM   #20
CPBecker's Avatar
1977 27' Overlander
Shoreham , New York
Question
I have a 1977 Overlander that my wife & I purchased this past December. We are in the process of restoring it. I have the exact same problem with the step! I am also looking to learn how to fix it.
CPBecker is offline   Reply With Quote
Old 03-19-2019, 06:03 PM   #21
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by Al and Missy View Post
Someone had replaced one of the bolts holding the steps to the outrigger on my trailer with a standard hex head bolt. Over time the nut loosened and the bolt wallowed out the end of the slot in the outrigger such that it would no longer hold. Following the suggestion of a repair post I found on here I ground out the end of the slot a little and bought the replacement part at the Salem rally from the Airstream booth. IIRC it was around $4. I had to bend out the bottom of the slot where it changed directions into the lock position to get the shoulder head bolt in and then beat it back into place.
I didn't go to the ODM web page, but an alternative might be found here:
https://www.mcmaster.com/shoulder-screws.
Al
X2
I had to file the lock slot profile and replace the arm stud with a hardened bolt that I removed the threads from where it locks in the slot,(threads would just hasten ware)....POI, keep everything well lubricated.
ID:	336089   Click image for larger version
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 03-19-2019, 06:51 PM   #22
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Can you please post some pictures of this modification?
Originally Posted by absteen View Post
On my new trailer, I have a custom manufactured bracket that a fellow Airstreamer loaned me that rests against the frame and body, and hooks over the back of the lower step. This takes the fulcrum weight off the lower step and saves wear and tear on the step, and possibly your booty. This unit is shaped like an "H" with a welded steel angle iron on one end for the step, and a bolt welded to a piece of round bar. the bolt is adjustable within the longitudinal rod for length, and the round bar engages the joint between frame and lower body panel. This takes all the spring out of that lower step,Andrew, K6STN
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 03-20-2019, 07:48 AM   #23
Streamracer's Avatar
1986 25' Sovereign
Huntsville , Alabama
On my dad's 89 excella, the corner of the swoosh rounded off and steps would not lock into place. He ordered new outriggers but before replacing them he took the trailer to a welder who built up the corner and then took a die grinder to square up like new. Worked for years until he sold it. Still has the new ones in the shed.
Streamracer is offline   Reply With Quote
Old 03-20-2019, 09:02 AM   #24
1981 31' Excella II
New Market , Alabama
I had to work on mine some when I got the trailer 81 Excella II. They work fine now. Looks like you could remove the lower step and rob parts off it to fix the upper step at least till you can get parts.
Here is a post I made a while back and they have worked since then.
http://www.airforums.com/forums/f475...one-92563.html
Perry
Old 03-21-2019, 12:28 PM   #25
the ponz's Avatar
Detroit , Michigan
This morning I managed to totally disassemble the steps. A few of the allen type bolts worked loose, but most of the hardware was rusted to the point where a dremel cutting wheel, vice grips and heat were required to remove them. I only had to drill one large bolt and used an easy-out and more heat to remove it. Two of the smaller bolts also required drilling. All the threads in the treads looked fine and were chased easily. I plan to order all the replacement hardware and reassemble (which should be a heck of lot easier than the disassembly).
I am considering using anti-seize on the hardware, in an effort to avoid future corrosion, and include a more detailed inspection of the hardware in my yearly preventative maintenance program, as well as torque checks every time I set up camp. Any comments or suggestions?
I rarely deploy the lower step, but when I do, I have a large block of wood which fits snug between the step and the ground. I'll speak to my machinist neighbor about fabricating an H bar type support.
86' 31' Sovereign
the ponz is offline   Reply With Quote
Old 03-21-2019, 01:22 PM   #26
ft. myers , Florida
Originally Posted by the ponz View Post
Thanks for the replies.
So I looked at the Out of Doors parts page and found the necessary hardware.
Cost to replace all hardware, $292.40 for 16 points of contact.
Has anyone found a more reasonable solution? I will be visiting my favorite hardware store later today.
You want to lube those points every 60 days or so.
good luck
fladealer is offline   Reply With Quote
Old 03-22-2019, 03:16 PM   #27
the ponz's Avatar
Detroit , Michigan
step stabilizer bar info here
http://odmrv.com/catalog/index.php?m...oducts_id=1514
86' 31' Sovereign
Old 03-22-2019, 04:37 PM   #28
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
I had a Torklift GlowStep, Revolution, installed in JC. They are a definite upgrade from the original steps. Very sturdy and adjustable for different terrains. They contact the ground so, no diving board effect when using them. I believe they make a special step system for Airstreams, so easy fit too. Here is a link for the Glowstep Revolution.
https://torkliftcentral.com/rving-an...iAAEgJU5vD_BwE
Hiho Silver is online now   Reply With Quote
Bent entrance step aemers22 On The Road... 2 07-06-2017 07:03 AM
I know one of you will know how to... AIR-Quarius Cleaning, Stripping & Polishing 1 05-31-2014 10:45 PM
Argosy entrance step argosyman Steps 4 04-28-2011 08:52 AM
drop down entrance step repair jasper2222 Steps 16 05-31-2005 11:24 AM
Entrance door hardware 72 Overlander 1 Doors & Locks 7 01-14-2004 07:17 PM
