Old 12-07-2013, 09:07 AM   #1
2009 22' Interstate
Prairie du Chien , Wisconsin
electric step on 2009 Airstream 3500 stuck
We just purchased a 2009 Airstream Interstate in Tx and before arriving back in WI, the step stuck in the extended position. The wall switch in off so we are not sure how to get the step to retract. Any help will be appreciated. We are 1,000 miles from the selling dealer and 500 miles from Airstream.
bfbroadbent is offline   Reply With Quote
Old 12-07-2013, 09:18 AM   #2
Central , Mississippi
Try this-
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 12-07-2013, 09:19 AM   #3
Oh, and welcome to the forum!
Old 12-07-2013, 10:05 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The step has a "step lock" switch just inside the sliding side door. First switch is the patio light, second switch is the step lock. Mine has the switch wired upside down, so that up is off, down is on, backwards from all the other switches. Took me ages to figure out the switch worked backwards.
HOWEVER, the step should also retract even if the step lock is on, as soon as you start the engine. Unless the previous owner mucked around with the auto-retract feature as some here on the Forums have, to allow the step to be used for boarding passengers with the engine running.
Originally Posted by HiHoAgRV View Post
Try this-
The video is for the wrong type of step…
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-07-2013, 03:34 PM   #5
2009 22' Interstate
We know the step should retract and since it doesn't we should get a warning beep. But we are not getting a warning beep. Maybe this is another clue? Hope so. Thanks for all your efforts to help us.
Betty
Old 12-07-2013, 03:44 PM   #6
Betty
No warning beep and no movement means that a blown fuse is a possibility.
If memory serves, the step is powered from the chassis battery, not the house batteries. That means the fuse should be somewhere on the auxiliary panel on the base of the driver's seat if I'm not mistaken, not on the house fuse panel under the rear sofa.
On the plus side, even if you can't find the problem, the step doesn't stick out any farther than the passenger-side outside mirror, so as long as you avoid scraping it on a curb during a right-hand turn, the vehicle is still drivable that way.
WBCCI #1105
TAC LA-4
Old 12-07-2013, 07:33 PM   #7
2009 22' Interstate
We look forward to learning all we can about the Airstream. I think we are really going to enjoy our travels in it.
Old 12-08-2013, 04:29 AM   #8
It's great that you can say that even after encountering a problem so early in your ownership!
Even before my first camping trip, someone burglarized mine. During my first trip, a malfunctioning water heater thermostat allowed the water to overheat, nearly scalding me the first night I used it, and then shutting down the water heater so that for the rest of the trip if I wanted hot water I had to heat it in a teakettle on the stove. On the plus side, heating bathwater in a teakettle reminds one in a hurry how to take sponge baths and conserve gray tank capacity!
Due to an insurance settlement and a warranty repair, I got past those problems, and I have never once regretted buying mine.
WBCCI #1105
TAC LA-4
Old 12-10-2013, 10:20 AM   #9
2009 22' Interstate
how do you reset the service engine message after an oil change
Our dealer changed the oil before we headed back to Wisconsin, but they couldn't figure out how to clear the service engine message. Does anyone have an answer. Thanks again for all who have responded - its good to know you are willing to share the things you have learned.
Old 12-10-2013, 10:26 AM   #10
Your Airstream dealer changed the oil? Or your Sprinter dealer?
You've got to go to the Sprinter dealer to get the code reset at the same time the oil is changed.
OR, for the same amount of money the Sprinter dealer will charge to reset the code once, buy an OBDII code reader, that will allow you to reset fault codes yuorself. Just don't reset fault codes until you know for sure that the problem has been taken care of.
WBCCI #1105
TAC LA-4
Old 12-11-2013, 08:23 AM   #11
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Try GOOGLE for the service light re-set. I do my daughters VW all the time and it's a simple multi step procedure. Maybe the sprinter has something like that for re-setting it.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 12-12-2013, 12:07 PM   #12
2009 22' Interstate
re set message after oil change
Thanks so much for recommending google. I found a message from 2012 and watched a video - showed my husband and he now knows how to reset this message. I will also try google to see if there is more info on our electric step. Anyway thanks much for the help!
Step by step how to replace a '69 Airstream wing window thesignlady Windows & Screens 26 04-06-2016 05:46 PM
Step by Step 1959 Over59 1954 - 1959 Overlander 237 11-18-2015 03:41 PM
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 09:47 PM
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 794 04-29-2013 07:49 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
