Old 12-14-2014, 09:50 AM   #1
WESTTOWN , New York
Electric motor for steps ?????
Why do the $145.00 electric motors for the steps look the same as the $40.00 motors for a chev pickup etc, electric window ?????
CMDR BOB is offline   Reply With Quote
Old 12-14-2014, 10:10 AM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Because you are looking at it through the eyes of an RV owner!
Dave
"LOVE and LOSS, are two of the greatest emotions one can experience. -- I went to school to learn about "WHAT GOES UP MUST COME DOWN" but I had to live my life to learn the lesson of: 'WITH LOVE THERE WILL BE SORROW'."
David Stewart. (after loosing my NAVIGATOR)
Old 12-14-2014, 10:11 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
What motor for what steps?
Doug and Cheryl
Old 12-14-2014, 11:35 AM   #4
WESTTOWN , New York
electric motor for steps
these steps and motor
Replacement Motor for Stromberg Carlson RV Electric Sliding Steps Stromberg Carlson Accessories and Parts SP-1636669
compared to this one
Cardone Reman/Window Lift Motor 42-130 at AutoZone.com
Old 12-14-2014, 02:11 PM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
What real Airstreams have electric steps?
MICHAEL
Old 12-14-2014, 02:24 PM   #6
terryV's Avatar
2002 31' Classic
Monroe , Iowa
Apparently mine doesn't. I sure wish it did, tho.
terryV is offline   Reply With Quote
Old 12-14-2014, 03:16 PM   #7
1978 Argosy 24
MooreHaven , Florida
looks slightly different in the mounting but i would think with a little effort could be made to work.That being said if you have to pay todays labor rate for a mechanic to do the rework you would not come out ahead
This is only temporary unless it works! Red Green
oldiesel is offline   Reply With Quote
Old 12-14-2014, 03:23 PM   #8
1974 Argosy 20
Kooskia , Idaho
Real motorhomes.
Old 12-14-2014, 03:31 PM   #9
1974 Argosy 20
Kooskia , Idaho
Ohhh, oooho (waves hand frantically): The $145 one is made in China! The other is remanufactured and probably was made originally in the US.
Actually I have no idea, you might try the $40 one and see how close it fits.
Old 12-14-2014, 03:35 PM   #10
1974 Argosy 20
Kooskia , Idaho
And the wiring is different.
Old 12-14-2014, 04:09 PM   #11
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
I replaced mine with the window motor and only the gears didn't mesh right but could transfer from the old one. Why did they put a motor from a car on steps, because that was available and cheap. Was it the right motor, NO, step motors are open to the weather and placed just right for wheels to throw up everything onto the motor. When I installed new one I made sure all the electric was protected from the elements. Silicone works wonders as a sealant.
Old 12-14-2014, 04:54 PM   #12
Slowpoke
Gnorts's Avatar
2012 27' Flying Cloud
Portland , Oregon
I looked at a non-reman, assumed to be new, unit on that Autozone link, and it was cheaper than the reman! Also probably Chinese. The difference between it and the RV part? Simple. Markup! Cut the molex connector off the old motor to use with the new one, and I bet it'll work fine. Both have 9-tooth output gears, so hopefully it would bolt right up.
Like the tortoise, travelin' slow with the house on our back
2012 FC27FB "Ted Zeppelin"
2010 Tundra Crewmax Platinum "Silver Rhino"
Gnorts is offline   Reply With Quote
Old 12-15-2014, 08:50 AM   #13
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
As I said above gears look same but didn't quite fit so using old worked, but forgot to mention steps quit 6 months later, turns out the safety mechanism is plastic rollers, 3 that turn into crumble cheese or with the strain of motor shutoff switch pressing on deform them. Solution exchange the rollers with 3/8 nuts, but a warning the steps are still dangerous make sure you have all the electric off when working around them, possible to lose a human part.
selling AO Smith 105 motor to replace original Armstrong blower motor eubank Furnaces, Heaters, Fireplaces & Air Conditioning 1 09-07-2010 10:09 AM
Trying to identify electric steps bkahler Mechanics Corner - Engines, Transmission & More... 3 07-26-2010 03:11 PM
Kwikee Electric Steps Pam Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 05-03-2008 08:07 PM
Electric Steps Over59 1960 - 1964 Overlander 3 01-12-2005 01:19 PM
T/T Electric steps anyone? Excella3287 Steps 0 03-05-2003 12:27 PM
