Old 10-18-2014, 07:44 PM   #1
1973 Argosy 20
Conroe , Texas
Dumb question need a fast solution :)
I just replaced the Outrigger for step attachment on my 1973 Argosy 20', and I didn't take a photo before I took it to parts
I highlighted on the photo : (what I downloaded from a website)
, So I can't push that lever all the way down because how I installed it the lever "bar" is above that bolt and now is hitting it. And honestly I don't know what am I missing , but how is that lever opens the steps? Any of you have a photo of it?
atti_mac is offline   Reply With Quote
Old 10-18-2014, 08:03 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
On my 1999 the latch holds the step up. I can't figure out the exact problem here. Can u elaborate what you did?
Peace and Blessings..
Channing
WBCCI# 30676
Old 10-18-2014, 08:09 PM   #3
1973 Argosy 20
Conroe , Texas
I will try to take a photo tomorrow, but basically I cut it out a rusted outrigger , and welded a new one in. Put a bolt back what was holding the steps, and I can't push the lever all the way down anymore, and when I push the steps back nothing holds it up. So I guess something is missing. I don't remember how it was working before I took it to parts..
Old 10-18-2014, 08:32 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Placement of the latch bolt is important. If you have the old part you cut out you could compare the bolt hole location.
Also, there is a diagram somewhere but it lacks measurements. Have you Che kes the Out-October-doors Mart for an exploded diagram?
Channing
WBCCI# 30676
Old 10-18-2014, 09:34 PM   #5
1973 Argosy 20
Conroe , Texas
I can't find any exploded diagram
Old 10-18-2014, 10:02 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I do not find it either... maybe someone here can find it... don't worry, there is a fix!
Channing
WBCCI# 30676
Old 10-18-2014, 10:44 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Here is what it looks like on our '74 Argosy 26'.
http://i1166.photobucket.com/albums/...s/Steps203.jpg
Are you using a countersunk bolt? Note the flat countersunk bolt.
Old 10-19-2014, 05:05 AM   #8
Baltimore , Maryland
doesn't the lever pull up not down?
Old 10-19-2014, 07:50 AM   #9
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
In the pic in post 7 the lever pushes down. Which releases the rear arm from the latch at the rear of the slot.. The square shaft at the rear connects to the release latch on the opposite side of the step(s).
Are you sure the rear arm is going back far enough to where the latch catches it? There is a spring which holds the lever up. Is it in place?
Old 10-19-2014, 07:59 AM   #10
1981 31' Excella II
New Market , Alabama
Maybe this will help.
Perry
Old 10-19-2014, 10:30 AM   #11
janeinthemtns
1985 31' Excella
near Chama , New Mexico
I can't get my lower step down since I put it up for some reason last year. Maybe this will help me operate it.
janeinthemtns is offline   Reply With Quote
Old 10-20-2014, 03:56 PM   #12
1973 Argosy 20
Conroe , Texas
I think I found a problem. I will post a photo soon. I will have to cut out a piece... It is blocking the lever.. Can't push it down enough to hold the step.
Old 10-20-2014, 05:57 PM   #13
1973 Argosy 20
Conroe , Texas
Here is the photo. So The outrigger has an extra "plate" marked with yellow, what I didn't have on the original piece. So because of that , you can see the lever can't go further down because hitting the end of that plate. My spring just hanging now, please ignore that , I didn't have a time to drill a hole and attach it yet.
So as you see on the photo I highlighted with a red circle the point where my lever hitting that plate. And I am guessing the way it suppose to work , the lever goes a bit lower and will block the "pin" to slide back down to open the steps right?
I don't know how easy access to cut a piece off of that "plate" hope is not difficult
Old 10-21-2014, 12:18 AM   #14
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
don't cut the plate...
I think that 'plate' is there to improve stability of the whole side of the plate. I would 'trim' off the end so that the lever can move freely.. do not trim the lever.. just the end of the plate.
Now, when I look real close at the 'lever'... if you look above the point where the lever hits the 'plate', you can see that the lever actually 'tapers' on the top... if that lever were inverted, you might not need to 'trim' the plate. except that the end turns out... is there another lever on the other side? maybe you have them reversed?
if you decide to 'trim', I would use an angle grinder...
Channing
WBCCI# 30676
Need help fast! Bettye Refrigerators 7 05-21-2010 08:35 AM
Need width size of 66 Tradewind FAST! cclarkego Off Topic Forum 2 07-30-2009 05:39 PM
A Sewer Solution.... Solution FreshAir Waste Systems, Tanks & Totes 15 09-29-2007 10:23 AM
Water Damage?! Need Help Fast! ob1coby Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 04-30-2007 08:55 PM
Dumb,dumb, and dumber rebel beck Electrical - Systems, Generators, Batteries & Solar 13 04-03-2006 11:11 AM
