Old 05-30-2005, 06:58 PM   #15
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Steve look at Andy's exploded drawing. Make certain that all the parts are there, I'm fairly certain they are. Next pull the steps out and lie on the ground. Look under the steps and to the side on piece 29 aft and piece 8 forward, I hope that is the right piece numbers hard to see, there is a notch at the end of the slot all the way outboard. The flatbar braces help hold the steps upright so that the fastner piece 14 will catch in the notch. My guess is that piece 14 is riding in the slot and not catching in the notch. This will allow the steps to hang and not be a stable platform when you step on it. There is also a aftermarket prop that a friend of mine makes that fits on the back of the bottom step and against the trailer frame that prevents the steps from moving. When my screw failed on one of my braces it allowed the steps to fall just enough that they wouldn't catch on the notch on one side. Hope this helps.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 05-31-2005, 11:10 AM   #16
Steve Heywood.
Check the slots in the outriggers.
From your description, it sounds like they are severely worn.
When the slots become elongated, the step will droop downward, as you described.
The fix is replacing the outriggers, or welding up the holes, and carefully remake the new slots.
Old 05-31-2005, 11:24 AM   #17
Excella3287's Avatar
This is really a simple fix having gone thru this myself. Using an arch welder build a spot at the end of the runners, using a dremel grind it down for finish. Not complicated and only about 2 hours of time.
Excella3287 is offline   Reply With Quote
Bed Glide Repair Tamara General Interior Topics 16 08-31-2006 08:28 PM
Need a step? jcanavera 2001 Safari 8 01-26-2003 11:05 AM
Handy hitch step Pahaska Our Community 0 06-26-2002 05:44 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
Door Step Pick Steps 0 06-17-2002 09:05 PM
