Old 09-27-2017, 01:35 PM   #1
1995 30' Excella
Harper Woods , Michigan
droopy aluminum step - a kludge compensation until something better can be done.
Hello,
I'm working on a lot of things right now, on a recently acquired '94 28' Excella, and the neighbors of all ages are curious to look. Well, the bottom step is a bit dodgy because it droops down & out due to wear of the upper aluminum step. This could be a hazard for someone who is a bit unsteady on their feet. So I dropped a couple of 8D waffle-headed nails into the corners, between the struts and the upper step, to compensate for the wear, until I can do better. Does a fix already exist?
ID:	295698   Click image for larger version
Bob Blarney is offline   Reply With Quote
Old 09-27-2017, 07:13 PM   #2
1981 31' Excella II
New Market , Alabama
Have a welder fill in the worn away portion and then grind it back to where it should be.
Perry
Old 09-28-2017, 01:21 AM   #3
Road Geezer
Road Geezer's Avatar
2011 27' FB Flying Cloud
San Jose , California
Images: 34
You can buy a short post that fits under the bottom step and supports it. Ive seen it on SOBs at RV parks. Camping World probably has them.
As far as I know, this is the oldest I've ever been.
Road Geezer is offline   Reply With Quote
Old 09-28-2017, 04:03 AM   #4
1972 25' Tradewind
Detroit , Michigan
Replace it
You could buy new steps: http://www.inlandrv.com/catalog/prod...roducts_id=849
In 1975 I bought a '68 Ford Mustang in near perfect condition for less than these steps. I would stick with the nail.... it shows ingenuity.
TR Anderson is offline   Reply With Quote
Old 09-28-2017, 05:00 AM   #5
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Maybe a machine shop can fabricate the few parts you need replacing.
Old 09-28-2017, 08:55 AM   #6
1995 30' Excella
The problem is that the weightbearing surface area is too small & soft. Maybe a thicker, say 1/2" wide x 1/2" x 2" bar can be welded or bolted on.
Old 09-28-2017, 09:13 AM   #7
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Seems like you could get a welding shop to weld a bead/a little bit of aluminum weld material right there.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-28-2017, 09:26 AM   #8
Mollysdad's Avatar
How about leaving the bottom step folded and using this?
Mine supports 1000# and is very sturdy. Folds for travel.
Old 09-28-2017, 10:15 AM   #9
Traveler
TravlinMan's Avatar
2017 25' International
Staunton , Virginia
I like that.
TravlinMan is offline   Reply With Quote
Old 09-28-2017, 11:33 AM   #10
TAC CA-420
'55 Airlight's Avatar
Santa Monica , California
Images: 104
Elkhart Tool and Die has been making camper steps, among other things, since the 1950s, I think. Here's a link to the accessory you've been asking for. <http://www.elkharttool.com/accessories.html>
If you're planning on doing a lot of rallies you'll discover that some pretty big folks will put a lot of weight on those steps. I've seen original 1946 Spartan "Manor" steps destroyed at a rally open house by a gal that must've gone three bills. That restored Spartan now has a portable wooden box step for rally open houses.
<M>
"Of the gladdest moments in human life, methinks, is the departure upon a distant journey into unknown lands... A journey, in fact, appeals to Imagination, to Memory, to Hope,—the three sister Graces of our moral being.’
Sir Richard Francis Burton
'55 Airlight is offline   Reply With Quote
Old 09-28-2017, 12:11 PM   #11
onelisab's Avatar
1976 27' Overlander
Lubbock , Texas
DITTO Mollysdad.
Exactly what we do.
onelisab is offline   Reply With Quote
Old 09-28-2017, 01:36 PM   #12
1981 31' Excella II
I rarely use the second step.
Perry
Old 09-28-2017, 01:40 PM   #13
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Took ours off.
Alan
AlinCal is offline   Reply With Quote
Old 09-28-2017, 06:30 PM   #14
2000 34' Limited
1985 25' Sovereign
LaGrange Highlands , Illinois
Originally Posted by Bob Blarney View Post
Hello,
If U R interested I have the fix for UR lower step I have braces that will put them back up where they belong.
The braces R $18.00 a pair plus shipping and instructions. I have put many of these on Airstream trailers and sold many to people that wanted to put them on themself. Contact jematkovich@aol.com Cell 708-567-4686. wbcci #1790
rmatkovich is offline   Reply With Quote
Loss-of-use compensation. The Pirate Insurance & Claims 15 04-16-2018 05:44 PM
Which would you rather? Better brakes, better hitch, or better wheels/tires? bjmckernan General Repair Forum 30 07-17-2016 06:47 AM
Tomorrow, Tomorrow, I can't wait until tomorrow! thecatsandi 2006 - 2010 Classic (all lengths) 8 04-05-2006 03:55 AM
Droopy Rear End (Motorhome) smily Mechanics Corner - Engines, Transmission & More... 57 02-10-2004 10:17 AM
How long until the cure of Aluminum Fever? Rod Pease Our Community 14 01-10-2003 09:39 PM
