Old 04-24-2014, 06:51 AM   #1
crazie_eddie's Avatar
On the Road , Michigan
Can I fix a bent step?
The steps aren't fully retracting, and sometimes don't extend all the way. I suspect the problem is a bent component - the guide slot I guess you'd call it. The rig is a 1997 Land Yacht.
Can I bend it back into workable shape with the careful application of a hammer? Should I heat the metal first?
"No idea how it happened" he said, but I suspect it happened at the motorcycle rally or deer camp last year...
Many thanks for any advice you can offer!
Pat
Name:	bent step IMG_4580.jpg
crazy eddie
"Of all the things I've lost, I miss my mind the most."
crazie_eddie is offline   Reply With Quote
Old 04-24-2014, 07:06 AM   #2
dznf0g's Avatar
Oswego , Illinois
I would re-work it with hammer and some body tools, if necessary. Can you get to the underneath side? I would think you are going to have to remove the step or find some way to hold it firm. Just whacking at it while deployed will probably be ineffective and may loosen/bend other parts. Don't think heat will help, and may weaken the metal in that area.
-Rich-
Old 04-24-2014, 07:13 AM   #3
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
x2 - take it apart before you whack at it.
robert claus is offline   Reply With Quote
Old 04-24-2014, 09:22 AM   #4
1981 31' Excella II
New Market , Alabama
That is minor. I would remove it and use a hard metal surface as a backer. Something like a vise or anvil would be best as a backer.
Good Luck
Perry
Old 04-24-2014, 09:46 AM   #5
Thanks guys, will give it a go.
Rich: Red Green is my hero - I fixed the body work on my van with duc-tape and it looks great! Just can't see how to use it to make the steps work...
crazy eddie
Old 04-24-2014, 09:58 AM   #6
dznf0g's Avatar
Oswego , Illinois
"Duct tape.....the handyman's best friend!"
-Rich-
Old 04-24-2014, 12:23 PM   #7
It worked! Thanks for the help!
(no duc-tape was harmed during the repair of this step)
crazy eddie
Step by Step 1959 Over59 1954 - 1959 Overlander 237 11-18-2015 03:41 PM
How About a Collection of Step by Step Repair Procedures? josephhh Airstream Motorhome Forums 32 07-06-2015 09:47 PM
STEP-BY-STEP Shell-Off Floor Replacement A-Merry-Can Repairing/Replacing Floor &/or Frame 794 04-29-2013 07:49 PM
Bent Rear Step Track - 2004 Classic gklott 2001 - 2005 Classic 4 05-08-2004 02:13 PM
Need step by step instructions Grady White Repairing/Replacing Floor &/or Frame 3 06-25-2002 02:35 PM
