Old 03-06-2015, 08:00 AM   #1
1979 Argosy Minuet 7.3 Metre
Lake Jackson , Texas
'78 Minuet 7.3 metre need step
Just purchased this camper and new to this forum, diving in head first by gutting out the entire unit, several issues to deal with but for now I seem to be having trouble getting info about the entry step. I downloaded the user manual which is extremely helpful but severely lacking on step info? It shows a photo and says that the trailer comes with a step. Duh! Well I need specifics, previous owner removed the step and riveted a belly section over the space. All I know is I have about 21" offset a little right of center from the door, as interior rocker switch by the door labeled "step". My guess is at one time it had a 21" single step with some type of automatic servo motor, any information about spec's or where I might locate a suitable replacement would be greatly appreciated. I'm not a stickler for OEM, mine will be a resto mod with little if any original argosy options, thanks in advance for any helpful wisdom.
cutndried is offline   Reply With Quote
Old 03-06-2015, 02:12 PM   #2
thehandyman's Avatar
1980 24' Caravelle
corpus christi , Texas
That would be the switch for the light out side over the door.
thehandyman is offline   Reply With Quote
Old 03-06-2015, 02:19 PM   #3
1980 24' Caravelle
My Caravelle is the Airstream version of your Minuet. The steps are a single manual slide out.
Old 03-06-2015, 10:14 PM   #4
Do you know of a source for that part or is it a salvage item?
Thanks for the info?
Old 03-07-2015, 10:22 PM   #5
1980 24' Caravelle
try vintage trailer supply
1978 Argosy Minuet 6.0 Metre :: 1978 Argosy by Airstream Minuet 6.0 Metre overlander64 Airstream Registry Discussions 0 08-19-2011 08:30 AM
Need Steps for our 1977 Argosy Minuet 6.0 Metre myboyburt Steps 2 07-31-2008 03:29 PM
Another Minuet 7.3 Metre May Be On-Board! overlander64 All Argosy Trailers 1 04-23-2003 09:42 PM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
