Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Steps
Old 02-11-2019, 08:41 AM   #1
1972 25' Tradewind
fort lauderdale , Florida
72 Step release mechanism
My frame is about ready to paint as part of my full monty restoration.
I really want to clean the loose rust away on the step outriggers but the "step release" is in the way.
I thought removing it would be relatively easy but not so.
The lever "looks" to be in 2 pieces but i think they are fused together. The plastic grommets where the bar runs through the outriggers are also very brittle and would like to replace those also.
Has anyone removed this piece with success? I thought about cutting it out but cannot find a replacement on any website.
Any insight on removal and/or replacement parts would be great.
Sorry, about the pics. No matter what I do, they post rotated.
thank you
ERic
ID:	333404   Click image for larger version
ID:	333406   Click image for larger version
ehodg66 is offline   Reply With Quote
Old 02-11-2019, 11:43 AM   #2
Paradise , Texas
There is no replacement. You would need to fabricate another if removed
What I do is lift the handle up. Paint the area, let dry, drop the handle down, paint everything that was missed. And let er go, it's lasted this long without rusting to pieces, anything you do will give it another 47 years...
Crackerman is offline   Reply With Quote
Old 02-11-2019, 02:32 PM   #3
1972 25' Tradewind
Thanks Crackerman,
I had a feeling that was going to be my only option. I do plan on replacing the spring though, its' looking rather tired.
thanks again
Eric
Old 04-21-2019, 07:55 PM   #4
1992 34' Limited
South bend , Indiana
You can use these!
I work at MORryde and had these built for my ‘92 classic. They touch the ground, gives you regular usage to your door and screw straight to the subfloor on the inside of your trailer. Let me if you would like more info. This is the first proto and I am hoping to have Airstream be our direct distributer.
ID:	338805   Click image for larger version
ID:	338807   Click image for larger version
Farren is offline   Reply With Quote
70's step release mechanism Chuck Steps 16 01-17-2020 02:44 PM
Broken step mechanism JBBeaubeaux General Repair Forum 2 06-09-2016 09:18 PM
Step release handle broke due to metal fatigue! How to repair? BentMetal All Argosy Trailers 3 05-24-2015 09:26 PM
