You might try re filing a notch in the area. It gets worn down over time and often can be repaired with some careful file work. The other thing that is often suggested is to have someone put a bit of weld into that area, which then can be filed into the proper notch. If the plate is too rusted or worn, you can get new outriggers with the slide cut into them from Inland, or an Airstream Dealer, but to install them takes quite a bit of effort as the belly pan, and banana wrap are involved, as well as more welding.
