Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Steps
Old 10-20-2006, 11:55 AM   #1
BB 55 Bubble
BB 55 Bubble's Avatar
Profile:  1955 16' Bubble
Bend , Oregon
2 questions about the outside
First is this step original to a 1955 bubble? there are 2 pictures below, need a better angle just ask. Can a replacement be found or a replica?
Second look at the toung of this trailer It is all but jacked up. I have seen some simular parts have the trailer parts changed that much that I can not replace (with some grinding and welding) this with new ones?
Name:	Step in from front.JPG
ID:	27222  Click image for larger version
Name:	Step out from top.JPG
There is a fine line between firefighter and Pyro. I am who ever is having the most fun!/
BB 55 Bubble is offline   Reply With Quote
Old 10-20-2006, 12:07 PM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Yes, that looks like an original step. No, OEM replacements are not available that I am aware of. It doesn't look to be in too bad of shape, is it structurallty sound? If so, just cleaning it up and painting it with POR-15 will make it look better and protect it from rust.
Huh? Tongue...it doesn't look bad either. Maybe I don't understand the question...
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Old 10-20-2006, 01:47 PM   #3
BB 55 Bubble
Bend , Oregon
The step works great! The frame for it is not so great, and the pull handle is a little worn. The guy that I am going to have do the welding thinks it is an easy fix; I was looking for some back up options.
The tong of the trailer is missing the lock handle release, it broke off The ball lock is about 50% its original size on the inside. The safety chain I do not think is so safe any more. My concern is that I will be investing a considerable amount of money into the trailer. I would hate to let this slide and watch my trailer pass me on the road!
Here are some pictures.
ID:	27226  Click image for larger version
ID:	27228  Click image for larger version
Old 10-20-2006, 02:36 PM   #4
garthbf
garthbf's Avatar
Profile:  1975 31' Sovereign
mount vernon , Washington
safety chain.
I am not sure what the law is but... when I had a equipment trailer made several years back they said that they could not just weld the chain to the trailer. so they welded a D shaped metal tang on the each side of the A frame. then with a hole drilled in each you can put whatever size of chain on with a shackle.
garthbf is offline   Reply With Quote
Old 10-20-2006, 04:17 PM   #5
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
Step looks great
I think the step is an incredibly good rebuild simply because of the diamond-plate steel present in your photos. My '67 Overlander has smooth plate-steel with traction strips. Additionally, the side pieces which provide a track for the step's action go all the way back to the frame member on mine.
Functionally, there is no reason to replace your step. If you have a desire for originalness, grind off the diamond pattern & stick on traction strips.
FWIW,
Tom
Last edited by TomW; 10-20-2006 at 04:34 PM. Reason: Added picture of step just before adding traction strips
Old 10-20-2006, 04:45 PM   #6
InsideOut
InsideOut's Avatar
1956 22' Safari
Images: 87
<snip>
The older ones had diamond plate...mine is almost identical & I am 100% sure it is original.
Maxwell's Step
Shari
Safari VS. Classic Questions kkrogh Our Community 24 12-20-2005 11:10 AM
Questions with regards to A/S Storage dbmarshall Our Community 12 11-01-2002 06:34 AM
Search Questions hex Forum How-To's & Support 4 10-15-2002 11:38 PM
Prospective AS owner with questions jborning Our Community 0 10-14-2002 08:50 PM
Polishing questions Charcigar Cleaning, Stripping & Polishing 0 02-27-2002 07:21 PM
