Old 05-09-2011, 10:18 AM   #1
flyingcloud's Avatar
2012 27' Flying Cloud
somewhere , on the road
Images: 8
Xzilon Coating from Sutton RV
Hi all -
We just ordered a 2012 Flying Cloud from George Sutton RV. They are recommending that we get a Xylon exterior sealant that they apply to the trailer at the dealership. Apparently they're the only dealer that does it and it prevents corrosion.
Does anyone have this on their trailer? Are you happy with it? More information would be appreciated.
Thank you!
Our blog: Aluminarium
Find & Share Great Campsites: Campendium
flyingcloud is offline   Reply With Quote
Old 05-09-2011, 10:28 AM   #2
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Correct spelling seems to be Xzilon.
Looks like it's expensive - how much are they asking to do the Airstream?
Al - K4GLU is offline   Reply With Quote
Old 05-09-2011, 10:34 AM   #3
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Hmm, if you Google either spelling, you'll sure get some varied opinions. Wonder what Andy's experience is? That being said, Sutton DOES have a good reputation.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 05-09-2011, 10:35 AM   #4
Images: 8
$1400 for 27 feet...
Old 05-09-2011, 10:42 AM   #5
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Pretty useless website: Xzilon® Molecular Adhesion
Example from FAQs:
"What is the Xzilon® Limited Warranty term?
If you have already purchased Xzilon®, review the Xzilon® Limited Warranty that you received from the selling dealership. Otherwise, ask your authorized Xzilon® selling dealer for more information."
The rest of the website is just as informative.
Vaughan
Old 05-09-2011, 11:00 AM   #6
Mike Leary's Avatar
Images: 11
Cripes, how would you warranty something like that? If someone is hyping it as a way to prevent scratches, I call bull.
Old 05-09-2011, 01:29 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
The aluminum surface is clearcoated prior to assembly. Usually the clearcoat fails due to filiform corrosion between the aluminum and the clearcoat rather than due to degradation of the upper surface of the clearcoat. Adding more clearcoat will not prevent it.
Old 05-09-2011, 02:45 PM   #8
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I have a good feeling that when you read the fine print you will find out that if the product fails that the dealer will reapply the product again at no charge to you.They will not repair any damage caused buy corrosion.Most customers fail to read the warranties.
Old 05-09-2011, 03:20 PM   #9
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
Id save my $$ for something else.
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 05-09-2011, 03:23 PM   #10
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
If you coat the lacquer on the aluminum, the coat bonds to the lacquer but does not change the bond of the lacquer to the aluminum. Any coating is as strong as the weakest electron-bond.
This will do nothing for your airstream, long term.
TX-16
Dave Park is offline   Reply With Quote
Old 05-09-2011, 04:48 PM   #11
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Additional dealer profit comes to mind.
Michelle TAC MT-0
Sarah, Snowball
Old 05-09-2011, 06:23 PM   #12
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You're not even coating the aluminum, you're coating the plasticoat that coats the aluminum. The only benefit would be along the edges where the plasticoat has been compromised, like around lights, windows, and seams.
Old 05-09-2011, 07:53 PM   #13
CanoeStream's Avatar
St. Cloud , Minnesota
I fully agree with every single negative opinion voiced on this product. Day in/ day out solar ultraviolet will eventually degrade the aluminum-plasticoat bond. I store inside and I still can't bet that I'll have better results at the 10, 12 or 15 year point.
For example, the ultraviolet protectors in spar varnishes are sacrificial; ie, they are destroyed as they do their job. Therefore spar varnishes have to be renewed every year. Is the warranty dependent on reapplication? You'll not want to be spending that kind of $$. Spend it on storage under cover in my opinion.
5 meter Langford Nahanni
Old 05-09-2011, 07:58 PM   #14
UAPachyderm's Avatar
2004 28' International CCD
Birmingham , Alabama
I agree
UAPachyderm is offline   Reply With Quote
corrosion, sealant
Stove Top Powder Coating Ganglin Stoves, Ovens & Microwaves 15 03-31-2017 09:54 AM
Corrosion Kirbys Ribs, Skins & Rivets 4 01-19-2011 06:39 PM
