Old 07-15-2015, 02:52 PM   #1
curnes's Avatar
2010 23' FB Flying Cloud
McMinnville , Oregon
Where to get clear coat
I need some clear coat for my 2000 Bambi. I understand I should get it at my dealer, however the closest dealer is 90 minutes away. Can anyone tell me what brand they sell and if there are suggestions as to how I might get some?
I read Nyalic is good but I cannot figure out how to buy this as well. When I try to purchase through their website, I get a message that the store is temporarily closed.
Thank you in advance.
Cameron
curnes is offline   Reply With Quote
Old 07-15-2015, 03:51 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Go to any auto body paint supply dealer. They should have all the information you need
2004 Excursion 4x4
Old 07-15-2015, 04:21 PM   #3
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Cameron
How much clear coat did you need, just touch up or the whole trailer? The Nyalic store seems to be working OK.Transportation
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 07-15-2015, 06:08 PM   #4
curnes's Avatar
I just need touch up.
Old 07-15-2015, 07:30 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I called. Directly to Nyalic.. Their number is at this link, bottom right.
NyalicŪ
Easy to work with... Compatible with existing coating.
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 07-16-2015, 12:46 PM   #6
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Paintforcars.com
NavyCorpsman is offline   Reply With Quote
Old 07-16-2015, 04:03 PM   #7
1996 25' Excella
Tillsonburg , Ontario
I go to P&S Trailer Service in Helena Ohio for my clear coating. When I had a minor peel after a really cold winter they suggested I just use clear enamel from a spray can to touch it up and keep the aluminum from oxidizing. If you spray thin coats crefully without excess that causes runs, you will not be able to tell the difference and the aluminum will be protected more than adequately
JCW
JCWDCW is offline   Reply With Quote
Old 07-27-2015, 04:39 PM   #8
curnes's Avatar
Here is what I ended up with. Not beautiful but should keep the filiform at bay. I got the corrosiion X and clear coat at the Portland area Airstream dealer. The guy at the parts department told me not to sand off the corrosion as i would scratch the metal. Also, you can plainly see where the new clear coat product is used.
ID:	244026   Click image for larger version
Old 07-28-2015, 07:29 AM   #9
1996 25' Excella
That kind of corrosion will need to be polished to remove it. That will leave a different finish but it will look better than the present corroded look.
JCW
Old 07-28-2015, 07:52 AM   #10
Clear coat
The after market clear coat that Airstream uses, can be obtained from "Airstream parts stocking dealers".
The present clear coat, is a 2 part paint.
Shipping it today, however, is some what of a challenge.
clear coat or plastic coat fpoulson Cleaning, Stripping & Polishing 1 10-26-2014 12:42 PM
Aluminum compatible clear coat, where to get? perryg114 Clearcoat, Exterior Paint & Trim 2 03-31-2012 11:26 AM
Clear coat finish on top James Schmidt Clearcoat, Exterior Paint & Trim 7 06-14-2006 09:26 PM
Ouestions 2-oxidation&clear coat Sharon Lee Cleaning, Stripping & Polishing 0 07-01-2002 08:20 AM
Condition of Clear coat James Schmidt 1993 Excella 1000 2 05-15-2002 08:23 AM
