Old 01-21-2007, 11:20 AM   #1
JimGolden's Avatar
1977 31' Excella 500
What's under the wide blue band?
Hey everyone,
This is probably a really dumb question, and I'm about 99% sure I already know the answer. But, on my '77 Excella, what is under the wide blue band down the side?
I should think it is just the aluminum panel that I see below and above. Should I expect it to be in better shape or worse shape than the rest of the aluminum if I pull the blue plastic piece off?
When I redo the body, I was thinking of eliminating the band and polishing the area in between. I may do away with the two trim bands (one above, one below) as well.
Not sure, just thinking. I like how the older trailers (say in the 50's) were very clean and devoid of all the trim. Just smooth aluminum. I like that look
- Jim
JimGolden is offline   Reply With Quote
Old 01-21-2007, 11:30 AM   #2
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Pretty aluminum
Nothing inder there but virgin aluminum with lots of sticky residue.
The trim however has lots of rivet holes under it.
I have seen a unit where the trim was removed and rivet plugged into the holes. Looked good.
Ken
smily is offline   Reply With Quote
Old 01-21-2007, 11:50 AM   #3
myboyburt's Avatar
1993 25' Excella
Beautiful , New Hampshire
Images: 12
Blue band taken off of our 93 Excella
Ken
We had the blue band taken off of our 93 Excella as it was in sad shape. We didn't have any rivet holes to deal with, it is all smooth aluminum.
We are very happy with the look of our trailer, looks vintage now (with the addtional changes that were done).
If anyone is interested the work was done by GSM Vehicles in Plattsburg, NY.
Name:	R1R From Balrgn.jpg
Michelle & Leon
New England Unit
myboyburt is offline   Reply With Quote
Old 01-21-2007, 12:39 PM   #4
Road Ruler's Avatar
Images: 38
That Airstream blue colour certainly dates the trailer. Some folks don't care but others do. It would look cleaner without the blue colour. Charcoal grey colours go well with the aluminum too.
Old 01-21-2007, 12:47 PM   #5
Jimarq's Avatar
2004 28' Classic
1965 20' Globetrotter
Stephenville , Texas
Images: 13
Our motorhome (Seymour) doesn't have the red/or blue band either. Fortunately, all of the sticky stuff was gone when we got him. We do still have the molding brackets above and below it but approximately 1/2 of the molding is missing. We too were wondering what we should do with that area but like your idea of just leaving it off - it does make it look more Vintage.
A previous owner had painted the nose of Seymour the charcoal gray color.
Jimmy and Marque (Zoey)
WBCCI#: 2344
Texas Highland Lakes Unit
Jimarq is offline   Reply With Quote
Old 01-21-2007, 01:44 PM   #6
JimGolden's Avatar
Sounds good! Any recommendations on what to use to get the sticky residue off? Would that Goo-Gone stuff be the right thing to use? WD-40? Anything I shoult NOT use on aluminum in the line of goop removers?
Thanks!
- Jim
Old 01-21-2007, 03:24 PM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If you are talking about the lower trim, the rub rail, if you take off the blue strip you will find it riveted to the skin. Under that there is a joint where the side wall skin is riveted to the lower skin which curves under the body. Since this joint was not intended to be visible it is kind of rough, at least on mine.
Old 01-21-2007, 03:28 PM   #8
Lumatic's Avatar
1993 34' Excella
Images: 16
PS
I just looked at your photo and saw what you are talking about. Try a heat gun to soften up the goo and plastic putty knives. There will still be a gooey film left you should be able to get off with a solvent.
Old 01-22-2007, 08:03 AM   #9
JimGolden's Avatar
Let's Go Mountaineers!
Yeah, I figured I'd leave the rub rail on, although I need new plastic moulding on it pretty much all the way around. I was thinking of removing the two that border the big blue band.
Of course my wife is a big WVU fan and she wanted to leave the blue band on and paint half of it gold. We'll see.....
I did concede to her that since I need a new awning, we could do a blue and gold striped one
Yeah, I'm a Mountaineer too
- Jim
Old 01-22-2007, 08:25 AM   #10
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Jim-
Actually, there is rumor that one of the Airstreams has a map to the National Treasure hidden under the blue. Perhaps yours has it! When getting ready to remove the vinyl use a heat gun to help warm up the adhesive.
These are availabel from U-Line for around $60. The secret is to get the vinyl warm enough for the adhesive to loosen without getting it too hot that the vinyl will melt. Once it is all off Acetone does a fine job of getting the remaining adhesive off.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 01-22-2007, 08:26 AM   #11
SwampBillies's Avatar
1972 31' Sovereign
1964 24' Tradewind
Plant City , Florida
Send a message via AIM to SwampBillies
A Fellow Mountaineer!
Go Wvu!!!
SwampBillies is offline   Reply With Quote
Old 01-22-2007, 10:41 AM   #12
JimGolden's Avatar
Hey Swampbilly, did you make it to the Gator Bowl? Great game!
My wife has a WVU bottle opener that plays the "fight song" every time you crack one open. I try to play it for her as much as I can
She was a "Bandor" and so likes to join all the other old crazis up there for Homecoming games to play her horn on the field. One of biggest uses I see when I get the Stream back on the road is to become a fixture at the coliseum parking lot with all the other RV nuts for the games up there. Those guys party pretty well. Plus, saves you $300 per game over what the local hotels get!
Rick I'll be looking for that map!
Thanks for the guidance!
- Jim
Old 01-22-2007, 10:49 AM   #13
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
I agree, heat gun
Has anyone that has done this had any issues with a ghost stripe - similar to the complaints you hear about removing club numbers? I've removed vinyl graphics from vehicles but never aluminum.
Dave
Fyrzowt is offline   Reply With Quote
Old 01-22-2007, 11:03 AM   #14
Craftsman
Guest
Posts: n/a
I had a terrible time removing the stripe from my 94 Classic. I tried everything starting with a heat gun and platic scraper to every solvent and stripper in my shop. None of it took it all off. I finally had to sand the final grey residue off.What a pain.
Blue paint uwe Clearcoat, Exterior Paint & Trim 52 09-17-2014 07:41 PM
blue trim molding larry smith Clearcoat, Exterior Paint & Trim 83 12-07-2003 11:04 AM
Bottom Band ? SAM Belly Pans & Banana Wraps 2 09-28-2002 08:33 PM
Painting your Airstream jkleven Clearcoat, Exterior Paint & Trim 25 07-18-2002 03:32 PM
Exterior Blue Vinyl Trim Danno Clearcoat, Exterior Paint & Trim 5 06-29-2002 04:15 PM
