Old 01-22-2007, 11:17 AM   #15
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Some are not easy!
There is a "feel" to using the heat gun - not too fast, not too slow. I had the best luck in getting a piece "started", then slowly heating as I pulled. Pull too fast and it tears, too slow and it begins to melt. I try not to use the putty tools except to get the handhold.
Dave
Fyrzowt is offline   Reply With Quote
Old 01-22-2007, 11:21 AM   #16
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Once you get the vinyl to start peeling point the heat towards the glue against the AS side. This way you are getting more heat into the glue rather than try to get the heat through the vinyl.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 01-22-2007, 11:27 AM   #17
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
Try Motsenbocker's Lift Off
Don't know if Motsenbocker's will work on the big blue stripe but it has worked for me when Goof-Off and other solvents will not work. Motsenbocker leaves a slightly oily residue so be prepared to wash it throughly with soapy water. You may even have to wash more than once.
I've used Motsenbocker's on painted surfaces and other metal surfaces with no signs of damage. I have never used it on aluminum so try it at your own risk.
Welcome to Motsenbocker's Lift Off
Lucius
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is online now   Reply With Quote
Old 01-22-2007, 06:40 PM   #18
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Leave it on!
Hi, leave the blue stripe on; That is what makes it look good and classy. We paid to have a set of blue stripe decals installed on our trailer. It looked so Plain Jane next to the Excella's.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-02-2007, 10:53 AM   #19
1990 34' Excella
Windcrest , Texas
What about the 90's?
Our Excella 1000 has a stripe that appears to be a sticker/decal instead of the vinyl mentioned in this post.
Any tips on removing this without damaging the clearcoat?
The stripe is fading and is still on the AS. What do you think about spraying clear coat on top of the stripe to reduce the impact of the fading?
Mitch
Swanny is offline   Reply With Quote
Old 06-07-2009, 06:49 PM   #20
1987 31' Excella
St Louis , Missouri
Funny, I was just explaining how I want to remove that UGLY blue stripe. I am only planning on removing the bottom piece of trim though, as I have a bent piece.
Any advise on removing that bottom piece of trim? I know I will have to replace the rivets...Should I use aluminum rivets? and are they standard rivets?
MarkWilde is offline   Reply With Quote
Old 06-07-2009, 07:27 PM   #21
shermybaby's Avatar
1956 26' Cruiser/Overlander
Kennewick , Washington
Images: 13
Send a message via Yahoo to shermybaby
I have used a heat gun to remove the vinyl portion and 3M™ Adhesive Remover Catalog Number 6041, 24 fluid oz, to get the sticky residue off.
shermybaby is offline   Reply With Quote
Blue paint uwe Clearcoat, Exterior Paint & Trim 52 09-17-2014 07:41 PM
blue trim molding larry smith Clearcoat, Exterior Paint & Trim 83 12-07-2003 11:04 AM
Bottom Band ? SAM Belly Pans & Banana Wraps 2 09-28-2002 08:33 PM
Painting your Airstream jkleven Clearcoat, Exterior Paint & Trim 25 07-18-2002 03:32 PM
Exterior Blue Vinyl Trim Danno Clearcoat, Exterior Paint & Trim 5 06-29-2002 04:15 PM
