Old 08-30-2016, 10:24 AM   #1
1972 29' Ambassador
Sag Harbor , New York
What's going on with this clearcoat?
So I have a 72 Ambassador and in front section that was rough area. I thought it was just the clearcoat, so after reading several posts here, I used citristrip to take it off. But after three rounds. 1 hour, 2 hours and 4 hours, it doesn't seem to have worked. It feels smoother and it pulled the clearcoat off from the top part of the panel, but not the center where I am having the issue. Can anyone tell me what's going on from looking at this photo and what the solution is?
Thanks.
SagStream is offline   Reply With Quote
Old 08-30-2016, 11:21 AM   #2
moparjohn's Avatar
1973 25' Tradewind
Ringoes , New Jersey
your photo did not come through
moparjohn is offline   Reply With Quote
Old 08-30-2016, 11:30 AM   #3
1972 29' Ambassador
Okay. I tried to upload it again.
Old 08-30-2016, 12:37 PM   #4
moparjohn's Avatar
1973 25' Tradewind
ok
so I can't tell what's with the center section, looks like maybe an acid like reaction, the top looks normal for the age. sorry but maybe another will have a better idea. Good luck, john
Old 08-30-2016, 12:49 PM   #5
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
Try plain old heavy duty paint stripper from the hardware store. Brush on wait,wipe off. None windy day,goggles, work gloves highly recommended. Stuff burns 1.8 seconds after contact on skin.;-) Careful of plastic parts or remove. Neutralize with mineral spirits. Worked for me. Good luck!
Cyquest is offline   Reply With Quote
Old 08-30-2016, 12:51 PM   #6
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
Ps. Work in small sections at a time.
Old 08-30-2016, 01:25 PM   #7
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
Are you sure there is clear coat there to strip?
Try a little polish, if it turns black the clear coat is already gone.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 08-30-2016, 03:36 PM   #8
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I believe the clear coat is gone. The bottom section looks like the aluminum is stained. There is a section on my trailer that looks the same way.
Dingo Girl is offline   Reply With Quote
Old 08-30-2016, 03:40 PM   #9
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I concur. The area that looks milky is where clearcoat has been compromised for some period of time and the aluminum has oxidized. Polishing will get rid of it.
https://youtu.be/ElRp8kOVdMA
Shari
Old 08-30-2016, 03:40 PM   #10
1972 29' Ambassador
AldeanFan, should I use NuShine II Grade F9 or something else?
Dingo Girl, do you just live with the stain? It's such a visible part of the body, I'd really like to get rid of it.
Old 08-30-2016, 05:31 PM   #11
AldeanFan's Avatar
1977 23' Safari
Are you planning to strip and polish the entire trailer or just improve that area?
Polishing the whole trailer is a huge commitment, but worth it to some, myself included.
There was a discussion recently, polishing not to a mirror shine or something like that.
Old 08-30-2016, 07:13 PM   #12
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Like insideout said it should polish out.
Old 08-31-2016, 11:55 AM   #13
1972 29' Ambassador
thank you all. I will try polishing it.
any suggestions on polish?
Old 08-31-2016, 12:06 PM   #14
InsideOut's Avatar
1956 22' Safari
Images: 108
There are as many methods of polishing as there are polished trailers...here's our take on it after having done two:
Polishing
Shari
Electric step on Interstate going, going, gone EddieTheWire Sprinter and B-van Forum 1 03-30-2016 09:45 PM
To clearcoat or not clearcoat ghatfield Clearcoat, Exterior Paint & Trim 2 11-15-2014 10:40 PM
mb 52 C going going...... goransons Refrigerators 5 08-23-2007 04:51 PM
Stripping...Clearcoat that is! InsideOut Cleaning, Stripping & Polishing 19 07-12-2003 08:59 PM
Small Clearcoat Repair advice needed JaceBeck Clearcoat, Exterior Paint & Trim 2 08-01-2002 08:01 AM
