Old 06-18-2005, 04:12 PM   #1
Davis's Avatar
1996 34' Excella
Americus , Georgia
What paint to use on roof ?
Hi ,
I would like to paint the center section of my 1991 34ft trailer with white paint so it will keep the temps a little cooler.I have seen some other older trailers with there roofs painted white and they did not look bad.What would be a good choice Kool Seal Elastoramic white or a Household exterior white paint ? Also would the white paint cause chaulking or white streaking after a rain ? Thanks for the info. Davis
Davis is offline   Reply With Quote
Old 06-18-2005, 04:17 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Rivet
I used Kool-Seal white on our Argosy with good results, but the white stuff it is made with will chalk down the sides of your coach, although not as bad as house paint. You will have to wash the trailer more frequently, but it does help. There is a thread that should be kicking around here, about white roofs on Airstreams. A forum search should find it for you.
Good luck with it.
Old 06-18-2005, 04:51 PM   #3
2003 25' Safari
Eden Prairie , Minnesota
The new trailers come with white roof too!
To paint yours I would follow the steps in painting an aluminum airplane. Strip off the clear, etch, alodine, zinc-chromate primer, and apply Dupont Imron single stage white paint.
Dan
dmac is offline   Reply With Quote
Old 07-27-2005, 09:37 PM   #4
Bradjun1's Avatar
1999 34' Limited
1962 19' Globetrotter
Northern , Minnesota
Davis,
I used Interlux Brightside Blu-Glo White. The color is great and it brushes on with almost no brush marks. I used the roll & tip method which is explained on the Interlux web site. I used 1qt. for a 25 foot trailer.
Bradjun1 is offline   Reply With Quote
Dark grey bottom paint. apple 1 Clearcoat, Exterior Paint & Trim 5 08-07-2009 11:23 AM
Stripping paint off aluminum tin can luv General Interior Topics 4 04-18-2004 09:32 PM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 05:39 PM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 01:35 PM
Help...re Paint GOOFUP Cat Clearcoat, Exterior Paint & Trim 3 04-18-2002 08:14 PM
