Old 04-15-2014, 10:40 AM   #1
judflor's Avatar
1977 31' Sovereign
Stuart , Florida
What kind of paint?
I am sure this topic has been addressed before. I have had extensive repair work done on the chassis of my 1977 Sovereign airstream. The person doing the repair work sprayed the frame with red oxide primer. The question is what kind/brand of paint should I use?
judflor is offline   Reply With Quote
Old 04-15-2014, 11:04 AM   #2
1981 31' Excella II
New Market , Alabama
You can use conventional spray or car paint. Primer does not usually have any rust preventative properties. It is very porous and absorbs water. Its purpose is to server as an adhesion layer. Since it is already there, you can just paint over it. Most of the time we use a product called POR15 to go in bare rusted metal. It is very tough and likes rusted metal.
This stuff Aluthane would work pretty well. It is similar to POR15 and you can brush it on. The aluminum in it will act like a rust preventative. This guy's web sight is not great but the paint is good stuff.
ALUTHANE aluminum metallic paint MCU Coating Info Page
Perry
Old 04-15-2014, 11:17 AM   #3
1977 Argosy 24
Milltown , Wisconsin
I use brush on RUST-OLEUM, It sticks to almost anything. I have used it on collector car frames for over 20 years, sticks like crazy and doesn't come off. Sold in quarts everywhere in many colors. Painted a farm gate I made of rusty well pipe 25 years ago, and it still looks OK.
ventport is offline   Reply With Quote
Old 04-15-2014, 01:46 PM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
For what its worth...I use either POR or Chassis Saver. Same stuff, different prices. Every Rustoleum job I have seen, exposed to the elements has failed. Rust pops thru within weeks.
Old 04-15-2014, 04:27 PM   #5
1981 31' Excella II
I have not had much luck with the Rustoleum.
Perry
Can I paint this kind of interior? veg hed General Interior Topics 5 01-09-2014 09:48 PM
What kind of Paint??? resurgam3191 All Argosy Trailers 4 08-21-2011 11:01 PM
What kind of interior paint 1971 Overlander/End caps dingy riverdreamer Upholstery, Blinds, Walls & Interior Finishes 5 05-24-2004 09:36 AM
What kind of paint for a louver cover for a wall panel heater cindy General Interior Topics 1 09-19-2002 08:38 AM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 05:39 PM
