08-13-2016, 09:54 AM
2002 22' International
2019 25' Flying Cloud
Austin
What is Defference between Lacquer and Enamel Clearcoat
I've been to the automotive stores looking at touchup spray cans to experiment on some spots on the trailer. I want to buy the spray but use a brush to apply. Now I notice that they sell 2 kinds: Clear Coat Acrylic Lacquer and Clear Coat Acrylic Enamel. What is the difference, if any, when I use it to touch up.
Also, I saw some posts that explain how the aluminum once exposed is grey and may need to be touched up with a silver paint. So I notice (Duplicolor brand) a variety of silver and grey paint sprays. Any recommendations on these shades?
08-13-2016, 10:20 AM
Princeton
, New Jersey
I don't think you want to do this without some Real Expert Advice. If you insist i would go to an auto body paint supply house and a good auto paint shop for information.
The can of worms is bigger than you think.
2004 Excursion 4x4
08-13-2016, 10:25 AM
Austin
Funny that you said that. I went to the NAPA automotive paint store in Albuquerque and asked the question. They really didn't help me. The "expert" said either one would work, but you can't put one on top of the other.
So....I decided I might get better advice off the forum than from the paint store.
08-13-2016, 10:29 AM
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
Unless you have some seriously large and unsightly spots, I would leave it alone.
The silver spray paint is a bad idea, and the spray clear has the potential to look very bad too.
That said, the lacquer is a lot easier to work with and will dry harder and much faster than any unactivated enamel.
I have used spray lacquer on some of my interior pieces, but over time I have become disappointed in its UV resistance.
Gradiens super tenui glacie.
08-13-2016, 11:02 AM
Princeton
, New Jersey
Keep in mind while NAPA may sell paint they are not an auto paint supply house. There is a difference.
There also is a difference between opinions and expertise. Opinions are free you might have to pay for expertise.
2004 Excursion 4x4
08-13-2016, 11:38 AM
1996 34' Excella
Elberta
, Alabama
An automotive paint supplier who sells DuPont finishes should be able to get him guided the right direction......In my experiences, lacquer finishes are a lot more forgiving than enamel....
Larry C
08-13-2016, 11:44 AM
2003 30' Classic
Fresno
Ok so...I have some spots just below the belt line trim and some around the upper lights. I am told it is corosan and I too would like to hide them in some way....Our AS is a 2003 Classic 30 and other than these few spots the outside and inside look new. What caused them and what cam I do to stop them from growing??? Thanks for your help.
08-13-2016, 12:07 PM
2012 30' Flying Cloud
San Antonio
To Tanker and Idireland: a quick lesson below. For detail info, look for other "how to" posts in that same "corrosion" thread.
http://www.airforums.com/forums/f142...ml#post1726310
08-13-2016, 01:14 PM
Crosby
Lacquer dries extremely fast and is easy to work with, if you spray it, it will appear somewhat dry when it has set up but it can be buffed to a high luster if wanted. Enamel is slower to dry but the finish will remain as is when dried. Keep in mind that you can spray enamel on top of lacquer at some point later if needed but you can not put lacquer on top of enamel or it will "lift". Most body shops now are using urethane clear coat which is very durable and easy to use. Hope this helps. Rob
08-14-2016, 04:54 PM
1990 29' Excella
Travelers Rest
, South Carolina
_____________________
You get one inexpensive chance to be right and many expensive chances to be wrong. Call Jackson Center and ask to talk with someone who is an expert on repairing the finish on Airstreams. Tell them the year of your AS. Aluminum has a different rate of expansion and contraction than steel, so many finishes may not be up to the coefficients of expansion that Aluminum has. If Jackson Center doesn't have time to talk to you, call P&S Airstream Repair in Helena, OH. They refinish one Airstream after another day after day, month after month. Don't rush into this. Acting on a wrong answer could really be a mess.
WBCCI 2456 Georgia Unit 32
1990 Excella 29' Centramatics
2016 GMC Sierra Crew Cab 2500 HD 4x4
6.6L Duramax + Allison, 3.73 axles
08-14-2016, 05:28 PM
2014 25' Flying Cloud
Temple
Laquer paint is a cellulose based paint in a volatile solvent that forms a film when the solvent evaporates - it is considered less durable than other types of paints but it was common on autos (especially popular for the old Corvettes)
Acrylic paints (or clear coats) are mixtures of acrylic resins and melamine resins, the resins crosslink after the solvent flashes forming a hard shell finish. They often have a catalyst added to enable the resins to crosslink after the solvent flashes (or evaporates) Many chemists consider the final film one large molecule, that is usually very hard and long lasting. This process is not curing or drying but rather a chemical reaction.
Years ago most resins were solvent based and insoluble in water however recent technology has produced resins that can be mixed with water, the water based acrylics are almost always finished with heat to flash the water and complete the cross linking reaction. Both clear coats and pigmented materials are similar except for the pigment.
Soda cans and beer cans often have acrylic coatings to protect the logos. After graduation from college I was a research paint chemist for several years 1970 - 74 and responsible for creating new types of coatings for drink containers, including water based clear coatings - after smelling like a solvent for 3 1/2 years I went back to college for 2 more degrees just to make sure that I could stay out of the paint business.
2014 Flying Cloud 25FB
2018 Ram 2500; Cummins
Blue Ox WDH
08-14-2016, 08:17 PM
1972 31' Sovereign
Benton
, Arkansas
Very good write up Ram!
I have to take exception to one point though, to the best of my knowledge, there has not been any nitro-cellulose lacquer available for decades.
The industry switched to acrylic based lacquer in the 60s or 70s.
I will add to this that I am not a real fan of uncatalyzed enamel, it cures way to slowly, and way too soft for my taste. I do however like catalyzed enamel.
08-15-2016, 08:57 AM
Temple
Correct about Lacquer being unavailable for a long time - guess I will have to work on my spelling too.
Blue Ox WDH
08-15-2016, 02:16 PM
Austin
Thanks to All
Thanks to all who gave me some advice and words of caution. I do have some more research to do before taking action. But if I want to do a touch-up, I suppose the clear acrylic lacquer will be it.
Truth is I have about 4 types of finish problems. Each one may take different approaches:
1. Peeling clear coat - a couple of these are now 4 inches long 1/4inch wide.
2. Filliform corrosion. Several, but only two or three are getting big enough to bother me.
3. Long scratch - Caused by tree limb or something else. A couple. The scratches may or may or may not be all the way through the clearcoat.
4. Front end "dings" in aluminum area outside of the rock guards. These are plentiful and I worry about it growing to a bunch of filliform corrosion. Not sure if can really deal with this large area.
I assume that many Airstream owners have dealt with one or more of these problems. I've been searching through forum for some "how-to" posts, but haven't found much yet. Howard L. pointed me to one post where they actually sprayed on the finish. I was hoping to confine my approach to just a little touch-up with a small brush by spraying lacquer into the top, or jar, and picking it up with the small brush.
If anyone can point me to other "how-to" step by step approaches, I would appreciate. My campground wifi service for the past month has been miserable, making browsing through long forums most miserable. Thanks
08-15-2016, 04:04 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
You can get the clear coat that Airstream uses in spray cans from Outdoors Mart. You can also get a aluminum polish that takes off oxidation from Outdoors mart. The polish is a chemical action with no grit. If you need to strip a small area you can use Citri strip but be sure to mask the area off carefully. Citri strip only works when it is fairly cool and damp and it does not dry out before it cuts the finish. You can scrape with a plastic scraper and wash it off with a hose.
Some woodworking stores still sell clear lacquer. But I think it has no UV resistance all and would not last long on a trailer.
08-29-2016, 05:29 AM
1991 35' Airstream 350
Beachburg
, Ontario
Does anyone know the paint code for the black/gray area around the side windows on a 1993 350LE motor home?
Or should I just use a flat black?
Howard and Ann Schutt
09-17-2016, 06:59 PM
1997 35' Cutter Bus Diesel Pusher
PEARBLOSSOM
You can put enamel over lacquer but you can't put lacquer over enamel.
10-15-2016, 08:44 PM
1984 31' Airstream310
Honokaa
, Hawaii
Or should I just use a flat black? Attachment 270269
I have Duplicolor T-183 on my list of things to get to match the paint around the bottom of our '84. Might be the same....
10-16-2016, 06:05 PM
PEARBLOSSOM
You can paint enamel over lacquer but not lacquer over enamel. Enamel also takes longer to dry so you would want to spray in a cleaner environment.
12-20-2016, 12:30 PM
USS REQUIN 481
1963 19' Globetrotter
1988 25' Excella
Reynolds
, Georgia
I just got off the phone with Steve in sales. Estimate was $5K to $6500.
"rivit,rivit"
