Old 08-15-2016, 05:04 PM   #15
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
You can get the clear coat that Airstream uses in spray cans from Outdoors Mart. You can also get a aluminum polish that takes off oxidation from Outdoors mart. The polish is a chemical action with no grit. If you need to strip a small area you can use Citri strip but be sure to mask the area off carefully. Citri strip only works when it is fairly cool and damp and it does not dry out before it cuts the finish. You can scrape with a plastic scraper and wash it off with a hose.
Some woodworking stores still sell clear lacquer. But I think it has no UV resistance all and would not last long on a trailer.
Old 08-29-2016, 06:29 AM   #16
OttawaValleyGuy's Avatar
1991 35' Airstream 350
Barry's Bay , Ontario
Does anyone know the paint code for the black/gray area around the side windows on a 1993 350LE motor home?
Or should I just use a flat black?Click image for larger version
Name:	ImageUploadedByAirstream Forums1472470155.824709.jpg
Howard and Ann Schutt
OttawaValleyGuy is offline   Reply With Quote
Old 09-17-2016, 07:59 PM   #17
1997 35' Cutter Bus Diesel Pusher
PEARBLOSSOM , California
You can put enamel over lacquer but you can't put lacquer over enamel.
jerryemeryde is offline   Reply With Quote
Old 10-15-2016, 09:44 PM   #18
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Or should I just use a flat black?Attachment 270269
I have Duplicolor T-183 on my list of things to get to match the paint around the bottom of our '84. Might be the same....
Waipio Rim is offline   Reply With Quote
Old 10-16-2016, 07:05 PM   #19
You can paint enamel over lacquer but not lacquer over enamel. Enamel also takes longer to dry so you would want to spray in a cleaner environment.
Old 12-20-2016, 01:30 PM   #20
USS REQUIN 481
Pariscope's Avatar
1963 19' Globetrotter
1988 25' Excella
Reynolds , Georgia
Originally Posted by dcasr View Post
_____________________
You get one inexpensive chance to be right and many expensive chances to be wrong. Call Jackson Center and ask to talk with someone who is an expert on repairing the finish on Airstreams. Tell them the year of your AS. Aluminum has a different rate of expansion and contraction than steel, so many finishes may not be up to the coefficients of expansion that Aluminum has. If Jackson Center doesn't have time to talk to you, call P&S Airstream Repair in Helena, OH. They refinish one Airstream after another day after day, month after month. Don't rush into this. Acting on a wrong answer could really be a mess.
I just got off the phone with Steve in sales. Estimate was $5K to $6500.
"rivit,rivit"
Pariscope is offline   Reply With Quote
lacquer stripping and polishing teddyspicnic Upholstery, Blinds, Walls & Interior Finishes 1 09-25-2012 09:03 AM
Chipped Sink Enamel ddunbar Sinks, Showers & Toilets 2 10-22-2010 04:32 AM
PlastiKote="Engine Enamel"? Sav'h Steve Clearcoat, Exterior Paint & Trim 6 03-07-2009 10:28 AM
POR-15 Topside Yacht Enamel mwmoss Clearcoat, Exterior Paint & Trim 9 08-04-2006 12:22 PM
What the Heck is Catalyzed Lacquer? fireflyinva Cabinets, Counter Tops & Furnishings 16 12-14-2005 10:24 PM
