Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 10-29-2003, 07:22 PM   #1
dufrain
dufrain's Avatar
Profile:
What can I duplicate the dark grey on the underwraps with
I made some repairs of the panels that wrap below the lower chrome strip on my 96 excella 1000.I used sheet aluminum so i need to try to match the dark grey of the rest of the panels.Any body have a close match spray paint.thanx
dufrain is offline   Reply With Quote
Old 10-29-2003, 07:35 PM   #2
j54mark
Profile:
The factory color is DuPont Centari 44146-A. This is a metalic grey, despite appearances to the contrary.
There is perfect match available from Dupli-Color, number T183. My recollection is that it is a GM metalic grey. Dupli-Color can be had at most auto parts stores.
I should think you need a primer compatible with aluminum as an undercoat.
Mark
Old 10-29-2003, 07:54 PM   #3
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
I have also heard rumor that sears toolbox gray is the same color. I would test it first, but it is said to be the lowest cost of the three choices.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 10-29-2003, 08:33 PM   #4
dufrain
dufrain's Avatar
Profile:
thanx guys that helps alot any suggestions on the primer,never have messed with aluminum painting.
Old 10-30-2003, 06:31 AM   #5
smily
"Still Working"
smily's Avatar
Profile:  North Charleston , South Carolina
Misled
Dont be misled,
I recently used the Duplicolor paint and it definitely is not a match!
It is close but obviously not even a match. I can show you the difference if you like.
If you really are looking for a match, you will have to go to Airstream and buy there 22 dollar a can OEM paint.
If you use the search feature and search grey paint you will find the exact match listed on this forum. And even more information to the effect.
Smily
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
smily is offline   Reply With Quote
Old 10-30-2003, 06:38 AM   #6
j54mark
Profile:
I did some touch up work on my '85 with the Dupli-Color and cannot tell which areas are factory paint, and which are mine. Except mine has fewer paint chips. However, there is no particular reason to believe that it is, in fact, an exact match for the factory mix.
Also, one must factor in possible fading over the years when trying to match paints, so even the factory paint may not give you a match to your paint.
Mark
Old 10-30-2003, 06:45 AM   #7
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 144
..........any suggestions on the primer
As recently as a couple of years ago you could purchase a Zinc Chromate primer in spray cans from Aviation Supply Houses.
Made specificaly for Aluminum. Fairly expensive, but worked great. Also highly toxic.
Dennis
WBCCI # 1113
AirForums #1737
Old 10-30-2003, 09:33 AM   #8
dufrain
dufrain's Avatar
Profile:
thanx guys for all the info
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 07:59 PM
grey water plumbing vent Cruiser Waste Systems, Tanks & Totes 6 07-14-2003 02:03 PM
No Grey Water Tank????? Anna Waste Systems, Tanks & Totes 16 11-17-2002 07:33 PM
grey water tank BIG question escapeez Waste Systems, Tanks & Totes 19 09-05-2002 06:52 AM
Dark grey bottom paint. apple 1 Clearcoat, Exterior Paint & Trim 1 04-07-2002 12:20 PM
