Old 11-25-2011, 09:31 PM   #15
reinergirl's Avatar
Hollis , New Hampshire
Yep, its just a big eraser.... wheel will disintegrate as u use it, won't hurt the aluminum and probably less aggressive than some of the chemicals you've been trying... I have no experience with it personally but as it's designed to remove decals and is relatively cheap (local auto stores around you may have eraser wheels as low as $8) not 3m but others..... worth a try!! I have one on order...
reinergirl is offline   Reply With Quote
Old 11-26-2011, 04:24 AM   #16
Baltimore , Maryland
Originally Posted by edglenn View Post
Wally's ghost haunts my trailer!!!
In the form of that damned blue sticker, front and rear!
What adhesive did they use, and how do you remove it?
I've tried everything, and I can't get that circular area clean and shiny.
I got the old decal off, but the adhesive remains.
I thought it might be etched into the aluminum, but it only shows up when I buff it with rubbing compound. I'm sure it's on the surface of the aluminum, but I can't get it to shine/polish up.
I've tried every chemical I can think of.
I've used stainless steel wool, and fine emery cloth.
I've buffed the area for 1/2 an hour in the same area with heavy compound. It won't budge!!!
What is it. How do I remove it?
Do I have to simply apply another BCCI decal over it?
Where do I get one, if I have to?
I hope you find a solution. I have seen this same decal do what you describe many times now. We have a trailer in for a polish right now and on the back someone actually tried a grinding wheel. (NOT being suggested by any means) It succeeded in removing parts of the decal along with many mils of metal. The last one we dealt with we couldn't get that round decal off either. It is now looked at as "history"
Old 11-26-2011, 06:54 AM   #17
65CV's Avatar
Western , Massachusetts
Ed-
I had the same problem with a decades-old Good Sam Club sticker. It was the kind that had cut-outs, so the ghosting showed behind areas that were covered and the uncovered areas matched the rest of the trailer. The PO used sandpaper with a pretty aggressive grit, so I had a bit of work to do.
Here's my theory of the ghosting:
Aluminum is much more porous than most people realize. As a result of that porosity, our trailers have oxidation far deeper into the skin than we would expect. We all know that aluminum oxide is a different color than pure aluminum.
The sticker slows oxidation of the metal underneath it. After decades, that subtle slowing will result in enough difference in the oxidation that you can see the difference. After "only" 1/2 hour of compounding, you haven't gone deep enough to get to a layer of aluminum that has equal amounts of oxidation in the protected versus the unprotected parts -- thus the ghosting.
I was able to get rid of most of Good Sam with 3 compound passes with F9, followed by another set of F7. I don't dare go too much further for fear of going through the AlClad layer. At this point, I think I'm the only one who can find Sam. I did see it slowly but progressively disappear.
John
65CV is offline   Reply With Quote
Old 11-26-2011, 08:00 AM   #18
1969 27' Overlander
Albuquerque , New Mexico
Thanks to everyone for the help!
I'm still inclined to believe that the "ghost" is residual adhesive, plus there would be some oxidation/etching, too.
Mechanically removing the material with an eraser wheel may be the only solution, but I'm still wondering if there isn't some adhesive remover out there.
As strange as it sounds,...peanut butter removes chewing gun and other gooey adhesives like price tags... I might actually try that.
(I just can't let the nosy neighbor see me smearing peanut butter on the trailer! He already thinks I'm nuts.)
Ed Glenn
edglenn is offline   Reply With Quote
Old 11-26-2011, 08:19 AM   #19
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Have you tried Goo Gone? Works for a lot of household stuff.
Old 11-26-2011, 10:53 PM   #20
1969 27' Overlander
I've tried everything, including Goo-gone, etc.
The peanut butter actually removed quite a bit of the old adhesive, and seemed to remove some of the oxidation, too!
Lot of black residue on the cloth when I wiped it off. I'm leaving another coat on overnight. Will see in the morning.
Ed Glenn
Old 11-28-2011, 08:22 PM   #21
1969 27' Overlander
Not the solution I'd hoped. I got the old adhesive off, but there is definitely some etching from the decal. Have to buff it out with compound.
So it's BOTH adhesive residue, AND etching.
Everyone was right!
Ed Glenn
Truck & Trailer Weights nickmeloy Towing, Tow Vehicles & Hitches 6 04-02-2014 10:02 AM
Termites in my Trailer acbolton Winterizing, Storage, Carports & Covers 4 06-09-2011 08:36 AM
The Wacky, Funky, Hicksville Trailer Palace Fly at Night On The Road... 0 06-05-2011 08:15 PM
How to remove door from trailer? nm1oqrz Doors & Locks 2 02-16-2011 07:57 PM
A sad end to a wonderful trailer rmk110761 Airstream History 9 02-15-2011 09:12 AM
