Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 08-19-2009, 08:02 PM   #1
Profile:  summit , New Jersey
vinyl trim
I have a 1997 airstream cutter. The vinyl trim on one side is faded to an ugly browish yellow color. Can I replace it. If so where do I get that type of trim?
cutbrain is offline   Reply With Quote
Old 08-19-2009, 09:19 PM   #2
Power to the People !
Maryw164's Avatar
Profile:  1972 31' Sovereign
SAN DIMAS , California
Send a message via AIM to Maryw164 Send a message via Skype™ to Maryw164
It would help if you specified exactly where the trim is: if inside, which room/area or outside and height location if outside. Or post a pic for others to see/reference.
Mary
Happy Trailering !
Forums member #29232
Check out my new Blogs (work in progress):
http://www.airforums.com/forums/blog...-maryw164.html
http://1972airstreamsovereign.blogspot.com/
Maryw164 is offline   Reply With Quote
Old 08-20-2009, 07:06 PM   #3
vinyl siding picture
I will see if I can get this to work. Attached is a representative example of the vinyl trim I am talking about. Let me know if this helps. If anyone knows an economical way to get an rv paint job for the exterior that would be helpful.
jc
Old 08-20-2009, 08:20 PM   #4
Maryw164's Avatar
Are you talking about the trim that goes around the wheel well? Your photo is a bit small and hard to make out.
Mary
Happy Trailering !
Old 08-21-2009, 08:21 AM   #5
vinyl trim
The white trim above the wheel. It extends to the length of the vehicle acting as a seal above the storage units.
Vinyl trim colour? Senshi Clearcoat, Exterior Paint & Trim 0 04-12-2009 02:05 PM
vinyl trim solution Isadora Clearcoat, Exterior Paint & Trim 13 07-30-2008 12:17 PM
Vinyl trim metalhead Upholstery, Blinds, Walls & Interior Finishes 9 07-23-2007 12:44 PM
vinyl trim piratesteve Upholstery, Blinds, Walls & Interior Finishes 0 09-23-2006 04:21 PM
front end vinyl trim, misc trim mlmarch Clearcoat, Exterior Paint & Trim 4 07-07-2003 11:29 AM
