Old 06-07-2012, 05:17 AM   #1
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Vinyl Stripe Removal and Replacement
I have removed the extruded aluminum molding and vinyl stripe around the beltline of my 86 Classic. The old woodgrain vinyl was badly weather worn, cracked and faded.
I tried the 3M large surface area removal wheel 07315 thinking that would rub it off. It does, but I spent 4 hours doing just the curb side. By then the wheel was worn from 8" dia new to 4" diameter.
Then I tried Kwik Kleen Aircraft Paint Stripper and wow, it was much faster and much cheaper. I applied liberally on about 5 feet, let it work for about 5 minutes, and then used an "plastic ice scraper" and just scraped it off. I had to repeat the process to get the adhesive residue off, and repeat a third time to get the stubborn spots.
I have ordered replacement vinyl in 7 1/2 inch wide gloss black, and the silver pin stripes. I have also ordered replacement rubber insert for the extruded aluminum moldings.
Pictures of the project so far:
Name:	1206 Vinyl Front Road.jpg
ID:	160318   Click image for larger version
Name:	1206 Stripper Works.jpg
Name:	1206 Vinyl Curb Center Removed.jpg
Old 06-07-2012, 07:52 PM   #2
Reganzo's Avatar
2006 34' Classic S/O
Lakewood , New Jersey
Where did you find the replacement vinyl?
Regards,
Reganzo
Reganzo is offline   Reply With Quote
Old 06-08-2012, 04:21 AM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Replacement vinyl stripes are readily available. Google it and you will have lots of choices. I went with vinylstriping.com as their price was better. I recommend the higher cost "cast" style vinyl for longer life. I also ordered the pin stripe rolls from this outfit too.
David
