Old 07-21-2011, 05:39 PM   #1
WBCCI 8562
Jim in Pima's Avatar
1975 31' Sovereign
Pelzer , South Carolina
Using Citristrip to take off clearcoat
I really didnot want to do this, and then found out the strippers many used on here are no longer available.
However about 1/3 of the clearcoat was LONG GONE, and some of the skin had been replaced and clear coated over grease and fingerprints.
So somewhere on here I saw mention of Citristrip, available here at Home Depot.
It took some disasters to get it right, 1st, left it on much too long, 2 tried to use plastic scrappers that really left a mess.
So bottom line, finished today..
Took about 1 gallon to do my 31 footer. Bought it a quart at a time.
I poured it in a plastic bowl, about a cup full. Using a 3 inch brush, I painted it on a small (4X4ft section) Let it sit till it turned grey, but not dry.
Taking a bucket of water and a large firm sponge I washed it off.
This left no marks on the surface that was still very shiny. Then rinsed it
with a hose. Then do the next area, about 15 minutes per section at 75F out. Going back over it later, I found small areas that did not come off the 1st time, so touch it up with citristrip and wash it again.
I was very concerned that a stripped would damage the new vinyl trip Ihad put on, and also attack seams, no problems..
I used a meduim rubbing compound where the NEW met the OLD, ie long lost clear coat..makes a neater edge.
Later I waxed the entire thing with Walbanise, at this point I am very happy with it and don not intent to do a high polish.
If you forget and it dries, paint it again with the stripper, wait about 10 minutes and wash it off do not try to scape it off, lots of scratches.
Jim in Pima Az, enjoying our 1975 31 ft Airstream Sovereign
Jim in Pima is offline   Reply With Quote
Old 07-21-2011, 05:52 PM   #2
1986 34.5' Airstream 345
Tyler , Texas
About a year ago I used the same method to strip my 345 and it seemed to be the easiest way to go. Start to finish it took me about 5 days of 3 hrs per day.
pjude is offline   Reply With Quote
Old 07-21-2011, 08:32 PM   #3
webspinner's Avatar
Menlo Park , California
Pictures?
Barbie
Our travel and renovation blog: http://tinpickle.blogspot.com/
webspinner is offline   Reply With Quote
Old 07-21-2011, 08:44 PM   #4
Central , Mississippi
Here's the sequence I used...
http://www.airforums.com/forums/f205...tml#post857709
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-21-2011, 09:24 PM   #5
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Hey jim I might have some of the proper stripper left removall 220. Vintage trailer use to sell it. I bought 3 buckets when I stripped mine. I think I have one full one left. let me know if you are interested I can take a look.
This stuff you put it on with a brush and it comes off with the hose!!!!
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-23-2011, 11:06 AM   #6
WBCCI 8562
1975 31' Sovereign
Smile
Hi, Thanks for the offer, however I am DONE, someday may do some polishing
with nuvite, but until them,.
Old 07-23-2011, 05:19 PM   #7
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Buy Removall, it takes a few hours to put it on and no time to get it off with the clearcoat then gone.It's still for sale, I just got a can and stripped my 66. Polishing now.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 04-28-2014, 09:19 PM   #8
1976 31' Sovereign
Bakersfield , California
Cheapest place to buy removall220
Update
Well, I've taken out my stove, toilet, and bottom of closet to have some plumbing leaks caused by pipe freeze of last owner. A friend as a plumber is a good thing! Need to replace facets. This trailer has been sitting for about 15 years.
I also will get new bearings and repackaged on axels.
Have no plans on getting on knees to just light frig so will update.
Trailer has been sun baked and looking to take off clearcoat then polish.
Where is the cheapest place to get removeall220 and how much should I get?Have no desire to sand.
Thanks guys
Ken
Bakersfield, CA.
1976 31 Sovereign
Kens76 is offline   Reply With Quote
Interior walls jhirstius Upholstery, Blinds, Walls & Interior Finishes 17 04-02-2012 11:35 PM
Anyone do Clearcoat in the Southeast? sound-silver Cleaning, Stripping & Polishing 3 07-12-2011 10:14 AM
Clearcoat to Maintain Appearance?? Help! big_john Clearcoat, Exterior Paint & Trim 0 05-30-2011 10:53 AM
