Old 06-03-2004, 07:07 PM   #1
Trim tape source(s)?
New to forum. New to Airstream ownership. Have 81 Excella that needs the blue trim tape replaced. Looking for sources of the trim tape. Also need instruction on removing the old tape which is badly dried and cracked.
RoyRK is offline   Reply With Quote
Old 06-03-2004, 07:17 PM   #2
markparker22's Avatar
1984 31' Excella
Santa Barbara , California
Excella Blue tape
My 1984 Excella has the same cracked tape condition. I have considered just painting the same color in a solid band in lieu of tape detail.
Mark
1984 31' Excella, mid bath, king size bed
1998 Chevrolet Suburban K2500, 7.4L/454 c.i., 4WD, Pullrite Hitch
AIR No. 2375
"You know... life is just the way it is...."
markparker22 is offline   Reply With Quote
Old 06-03-2004, 08:29 PM   #3
RichardT's Avatar
The tape is exremely hard to remove, a heat gun will soften it but you run the risk of overheating the aluminum and warping it, if you must use a hair dryer instead.
If it is not peeling consider cleaning it and applying the new tape directly over the old. I have started to remove mine and I am afraid It is one of those projects I wish I did not start at this time.
wait untillafter the summer and prepare to spend countless hours carefully picking at it.
If it is anything like mine, I wish you the best of luck.
Richardt
RichardT is offline   Reply With Quote
Fantastic Fan Airstream Trim Bezel - Where to buy? Joe Z Roof Vents, Skylights & Fans 11 01-09-2004 09:09 PM
Trim larrylisa General Interior Topics 8 04-05-2003 12:48 PM
black rub rail and trim insert wb13798 Airstream Motorhome Forums 2 01-30-2003 12:10 PM
Door Trim smily Doors & Locks 1 01-03-2003 08:27 PM
