Old 04-30-2018, 03:07 PM   #1
Leilanisteve's Avatar
2015 19' International
Boise , Idaho
Trim peeling
Iíve noticed this and havenít thought about it much but it was bugging me today while I was replacing lug nuts so I thought Iíd ask you kind folksí opinions.
The trim seems to be peeling and bubbling around most of the trailer. Near the front I noticed it flaking away. Will this lead to any damage in the future?
We bought this used late last year. Itís a 2015 International 19í
Steve
ID:	309862Click image for larger version
Leilanisteve is offline   Reply With Quote
Old 04-30-2018, 03:24 PM   #2
dznf0g's Avatar
Oswego , Illinois
Very common, very old problem. Use the search bar for alternatives.
-Rich-
Old 04-30-2018, 04:45 PM   #3
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I only got 5 years out of mine. Had it all replaced while having damage fixed at the factory last October. Surprised yours only lasted 3!
Old 05-01-2018, 09:04 AM   #4
Boise , Idaho
Thanks. Is it just aesthetic or something more structurally significant needing repairs? Search bar is not that helpful for other options.
Old 05-01-2018, 09:43 AM   #5
W , New England
Aesthetic as far as I know. Good luck!
Old 05-01-2018, 06:12 PM   #6
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Ordered a 100 ft roll for $112 spent about 5 hours removing old trim and glue residue now it is better than new.Went with a medium gray this time and looks great!
Old 05-01-2018, 06:14 PM   #7
W , New England
I asked the factory if they had black instead of silver - unfortunately not for a 2012....I imagine that would look stunning!
Old 05-01-2018, 08:23 PM   #8
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
The ProtektoTrim product is actually made by Cowles and is available through various auto body trim outlets/retailers/wholesalers for almost half the cost that Airstream asks. The matching 1" wide Chrome product number is 37-715 for a 100' roll and 37-314 for 30 feet. There are many colors offered by Cowles including black, blue, red, yellow and 'carbon fiber'.
http://cowlesproducts.com/oldcontent...color-molding/
An eBay listing: https://www.ebay.com/i/232740992579
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 05-01-2018, 08:42 PM   #9
2018 25' Flying Cloud
Hillsboro , Oregon
How about the lower wide trim? Thanks!
Roguegaston is offline   Reply With Quote
Old 04-22-2019, 08:15 PM   #10
2009 34' Classic
Greenfield , Indiana
CarID.com seems to have the lowest price on Cowles 37715 @ $141.91
skylane is offline   Reply With Quote
Old 04-23-2019, 05:18 AM   #11
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
After replacing the cheep plastic chrome hit & miss I went down a different road.
Starts here...thru 5596👍
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 04-23-2019, 05:52 AM   #12
eagletoo's Avatar
2020 23' Globetrotter
Long Island , New York
Fellow campers,
Upon close inspection of the belt line trim, there are several seams where the pieces meet/starts/ends. Looks like a good place for water to enter and start corrosion. Has anyone closed this gap with some type of sealant? If so, what did you use?
Thanks.
Bruce
2020 23í Globetrotter FBT Natural Elm/London Grey
2018 Jeep Overland 5.7L Hemi
Wally Bryan Airstream Club #2600
Iíd rather be camping is an understatement!
eagletoo is offline   Reply With Quote
Old 04-23-2019, 06:16 AM   #13
Originally Posted by eagletoo View Post
Fellow campers,
Thanks.
It doesn't 'corrode'...it's a cheep plastic chrome film poorly attached to the flexible molding extrusion.
It is a good idea to seal the screws under the insert that attach the aluminum base the AS.
W. H. Auden
Amanamus
"Tahawus"
Old 04-23-2019, 06:31 AM   #14
eagletoo's Avatar
Can I use a clear silicone to seal the screws? Is silicone ok to use with aluminum? Anyone?
Thank you.
Bruce
Old 04-23-2019, 06:58 AM   #15
Thank you.
I don't use sillycone...for the belt molding screws I used
3M 5200 Marine., it's best for permanent applications. One at a time, coat the threads tighten.
I have used 3M Marine Sealant on the AS & boat for years with excellent results. There are many options, Fast & slow cure, permanent and removable, UV(just used on my AC cover), and various colors.👍
W. H. Auden
Amanamus
"Tahawus"
Old 04-23-2019, 07:00 AM   #16
eagletoo's Avatar
Great info. Thank you, Bob.
Bruce
Old 04-23-2019, 07:42 AM   #17
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
I have replaced the trim on both our 23FB and 19' International. rather expensive for two trailers every couple of years.
I am going to try a different method and see how it works out. Please refer to the two pictures;
One picture is using 1" wide aluminum stripping available at the local ACE hardware store. comes in 6' length. Attaching using 1" wide double sided 3M tape.
The next picture is using the same aluminum strip, but painting with a blue reflective paint, letting it dry, then spraying with clear coat. Would like to see how this holds up.
ID:	338919   Click image for larger version
Steamy1 is offline   Reply With Quote
Old 04-23-2019, 08:19 AM   #18
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I used blue reflective tape. We'll see.
Old 05-26-2019, 11:03 AM   #19
honi soit qui mal y pense
Robere's Avatar
2015 23' FB Flying Cloud
Bend , Oregon
Has anyone used this method in years past and how has it held up? Looks promising and possibly long lasting. Cost?
Robere (aka Pepe) & Jacqueline (aka Gigi)
with pups Ella (the miniature poodle)
and Tibet (the Lhasa Apso)
2016 Chev Silverado LT Crew 4x4
Robere is offline   Reply With Quote
Trim Peeling cmmorsey Clearcoat, Exterior Paint & Trim 49 05-26-2019 10:43 AM
Trim peeling off sotastreamer Clearcoat, Exterior Paint & Trim 3 06-07-2017 09:44 AM
Tambour trim and trim Big C General Repair Forum 6 08-14-2012 08:01 PM
Exterior paint peeling! Astrodokk Airstream Motorhome Forums 2 08-10-2003 08:18 PM
front end vinyl trim, misc trim mlmarch Clearcoat, Exterior Paint & Trim 4 07-07-2003 10:29 AM
