Old 09-08-2015, 02:36 PM   #29
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Hopefully when I finally clean and wax the trailer the inserts in the two rubber rails will clean up. We've been too busy to clean and wax for three years and the rub rail inserts have become milky looking. The bottom one was installed at the factory in 2007 and the beltline one was installed at the service center a year or two later. For a couple of years Airtream dropped the beltline one to save money, but then people had more corrosion there and they went back to putting the beltline on.
I'd hate to replace them as it is one of those jobs where the replacement trim costs too much, preparation is tedious and putting new ones on isn't fun either.
Gene
Gene
Old 09-28-2015, 05:03 PM   #30
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Gene - The Protekto product is actually made by Cowles and is available through various auto body trim outlets/retailers/wholesalers for almost half the cost. The particular Chrome product number is 37-715 for a 150' reel (enough for two 34' trailers). I was able to get a 100' reel for $95 in Miami from an auto body shop a year ago for my 28'.
Here is a link for an outlet using a simple Google search to show how it is listed.
Terry's Auto Supply, Inc.
Application was fairly simple. Simply pull the old trim off, use a 1" plastic painter's spatula and some Goo-Off (or similar) for what tape remains, a wipe of mineral spirits to clean, and apply.
SeeMore is offline   Reply With Quote
Old 02-27-2016, 08:04 PM   #31
Utah Man's Avatar
2007 27' Classic FB
Richfield/SLC , Utah
Trim Peeling
Jackpot! This thread seems to have the solution to my new found problem (photo below) with peeling of the lower trim over the winter. I was bothered by the discoloration last year, but this looks like a great solution. I'll stay with the brighter silver colors, nothing too exotic.
Anyone who has used this (i.e. 1" Precision Trim, #37 Sheer Silver) have any second thoughts or updates?
Name:	ImageUploadedByAirstream Forums1456628472.877557.jpg
Utah Man is offline   Reply With Quote
Old 02-28-2016, 06:08 AM   #32
dznf0g's Avatar
Oswego , Illinois
No second thoughts no regrets. Still looks great.
-Rich-
Old 02-28-2016, 07:23 AM   #33
Utah Man's Avatar
2007 27' Classic FB
Good deal, thanks so much for sharing all the details and info.
Old 02-28-2016, 08:01 AM   #34
Senior Member
sheriff1's Avatar
2014 30' Flying Cloud
Sparks , Nevada
I just ordered mine. The old was easy to remove and left very little mess behind to clean off. I was surprised that the rivets had no sealant on the heads to keep water out. There was lots of water behind the molding. I will be sealing all of the heads before I install.
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
sheriff1 is offline   Reply With Quote
Old 02-28-2016, 03:52 PM   #35
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Utah Man - choose whatever finish you want. The nature of the material and UV exposure will age all at about the same rate except the red/orange spectrum which fades much quicker. The metallic reflective finishes (though plastic covered) seem to last a bit longer.
Sirs Gawain & Galahad
Air #48582, S/SO #003, WBCCI #4584
Old 03-03-2016, 05:42 PM   #36
Senior Member
sheriff1's Avatar
Sparks , Nevada
Just finished with this project. We decided to go with black to match the pinstripes and lettering. The 1" bottom used part#11100-60 , The belt is part#37130-60 from brandsport.com . prices were higher than I had seen posted here but items were in stock and free shipping. Old trim removed easily and really didn't leave much mess. Mineral spirits and scotch bright pad made short work of what was left. For a 27FB I ordered 80' of each and had 10'+ left over. Better than not enough!
Name:	ImageUploadedByAirstream Forums1457052071.585028.jpg
ID:	258097Click image for larger version
Name:	ImageUploadedByAirstream Forums1457052090.418731.jpg
ID:	258098Click image for larger version
Name:	ImageUploadedByAirstream Forums1457052103.932800.jpg
ID:	258099Click image for larger version
Name:	ImageUploadedByAirstream Forums1457052129.955565.jpg
Old 04-09-2016, 07:00 PM   #37
Utah Man's Avatar
2007 27' Classic FB
Done - really happy with the look of the #37 Sheer Silver. Appreciate the pointers here; suggestions worked well. Got the AS de-winterized and prepped today, only a couple more things to do before heading out to start the camping season -- soon.
Name:   ImageUploadedByAirstream Forums1460249942.907984.jpg
Name:   ImageUploadedByAirstream Forums1460249969.570586.jpg
Old 04-09-2016, 11:03 PM   #38
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
Attachment 258097Attachment 258098Attachment 258099Attachment 258100
That is really sharp looking, Airstream should consider going to black trim
Gary
Castaway is online now   Reply With Quote
Old 05-30-2016, 09:04 PM   #39
Durango , Colorado
Talking Rub Rail Trim Molding
sheriff 1,
Thanks for the great idea of using a black auto trim molding for my 19' 2007 Bambi LE. The black molding matches my graphics perfectly. My silver AS trim was falling apart and coming loose. I found the trim strip at Vinylgraphics.net made by Trim-Gard. A company established in 1968. Vinyl Graphics sent me a sample board with the different choices of Trim Gard. With the agents help I choose part #8002S black smooth which has just the right amount of sheen and matches the profile of the AS OEM perfectly. It is a true 1" width with slightly squared edge that matches the profile of the AS trim. It is backed with 2 strips of 3M Acrylic foam tape. Unlike some other trim samples that I received it is very flexible and easy to apply when at room temperature. The trim strip samples in black that I received from brandsport.com were actually 7/8" and not a full 1" so was a little bit to narrow for the AS Aluminum channel on the rub rail. I tried several products to clean the channel. 3M adhesive remover,(worked well) Prep All oil and grease remover (worked fantastic with 0000 steel wool) in a spray can, and finally denatured alcohol as recommend by Trim Gard as a final prep before applying the Trim Gard. The Prep All is amazing and safe for painted surfaces and the aluminum coating. However, I was as careful as possible to clean up any over spray with denatured alcohol. The Prep All spray can can be purchased at most paint stores.
Thanks again,
Ken Morrow
Durango, Co
ID:	263570   Click image for larger version
ID:	263572   Click image for larger version
ID:	263574   Click image for larger version
ID:	263576   Click image for larger version
pkm123 is offline   Reply With Quote
Old 05-30-2016, 11:18 PM   #40
Senior Member
sheriff1's Avatar
Sparks , Nevada
Looks great!
Old 05-31-2016, 08:59 AM   #41
Durango , Colorado
Cost
Forgot to mention that cost from Vinyl Graphics 79.95 plus 18.00 shipping for 50 foot roll. Also sold in 100 ft. Rolls.
Ken
jkm123 is offline   Reply With Quote
Old 05-15-2017, 05:56 AM   #42
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
nice the black trim is interesting for sure.. might have to give that a look.
great info.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Tambour trim and trim Big C General Repair Forum 6 08-14-2012 08:01 PM
Peeling Wallpaper Firecop General Interior Topics 2 11-23-2003 10:59 PM
Puzzled by peeling SCBrat Upholstery, Blinds, Walls & Interior Finishes 12 10-15-2003 07:37 PM
Exterior paint peeling! Astrodokk Airstream Motorhome Forums 2 08-10-2003 08:18 PM
front end vinyl trim, misc trim mlmarch Clearcoat, Exterior Paint & Trim 4 07-07-2003 10:29 AM
