Old 12-03-2011, 03:22 PM   #1
Bk Yd Safari's Avatar
2008 20' Safari
Tunnel Hill , Georgia
Trim Mold
Need help! I have lost the trim mold on one of the rock guards. The trim piece on the front corner, from the door around under the rock guard is now loose. How are these fastened to the body of the AS? Also any suggestions on finding a replacement strip for a 2008 20' Safari. I have attached a photo of the loose trim.
Steve
Remember its not the destination, but rather the journey.... its what's in the middle that matters the most!
Bk Yd Safari is offline   Reply With Quote
Old 12-03-2011, 03:48 PM   #2
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
You can get the molding from an Airstream authorized repair center... I'm not sure if there's another source or not. It will come with a blue protective film that you peel off. It is held into the track with a thin double-sided tape.
How do I know this? Part of ours was replaced when we had some body work done to fix damage from a blowout. The new moulding would not stay attached — partly because they used round-headed screws to attach the new track instead of flat head screws...so there wasn't good contact around the screws every 10" or so....so rather than replace all those screws and seal them, I used a thicker, extra strength outdoor double-sided tape to re-seat it. I think it was 3M brand, and I got it at Ace Hardware. The tape was exactly the width of the molding...and now that molding is NOT going anywhere.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Old 12-03-2011, 04:04 PM   #3
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Steve
One of mine turned to gas between there and here. Never noticed when it disappeared. Inland sells it by the foot. As I recall the bottom rub rail is 1" wide, the one that runs around the middle is 3/4". Clean the track really well with alcohol before peeling the backing off the tape, once on, peel the protective film off the front. They also carry it in black as well as chrome so be sure you order what you want. Most auto parts stores carry this, but none could provide it in those sizes when I checked. Find something else to order at the same time to make the shipping worthwhile.
http://www.inlandrv.com/catalog/index.php?cPath=65
Look at PN 70546
AIR 47751
Silver Goose is offline   Reply With Quote
Old 12-03-2011, 04:41 PM   #4
Ridgerunner3's Avatar
2002 25' Safari
Fountain Inn , South Carolina
Images: 13
I just installed some new rub rail on my Safari. Mine was 1" chrome. Andy at Inland also recommends that you apply black 3M weather strip adhesive to the back of the new chrome strip to make double sure it stays in place. It's relatively cheap and easy to install.
Ridgerunner3 is offline   Reply With Quote
68 tradewind blue trim 4gentradwind Ribs, Skins & Rivets 0 05-11-2011 09:28 PM
Rub Rail aka Body Trim aka ??? ukinusa Ribs, Skins & Rivets 3 02-16-2011 05:42 PM
interior trim around door removal? Bill M. General Interior Topics 2 01-24-2011 08:25 AM
