Old 08-14-2010, 08:15 AM   #1
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Trim above wheel well
Does anyone know where I can get the trim and the transition pieces for the wheel well. My 71 Overlander does not have it on either side. If not, has anyone ever manfactured something to work. Thanks
Mel
2006 GMC 1500 SLE Crew Cab
5.3L V8 Towing Package
Equal-i-zer E2
AIR # 40365
TAC # OK-3
mwells4654 is offline   Reply With Quote
Old 08-14-2010, 08:36 AM   #2
Ambie '64's Avatar
1964 28' Ambassador
Oklahoma City , Oklahoma
You can buy the j-molding at Vintage Trailer Supply. Look under the tab "even more exterior". The long part of the j-molding fits between the skin and the wheel well (don't try to encompass both skin and wheel well in the groove). If you want to replace the compound curve portion of the molding, you have to heat the material and bend it around a suitable diameter pipe. The use of clecos is a must when doing this part. It's a time-consuming job to do it correctly, but it sure sets off the wheel wells.
Hope that helps, and good luck!
Ambie '64 is offline   Reply With Quote
Old 08-14-2010, 09:41 AM   #3
1975 29' Ambassador
Reno , Nevada
re: "don't try to encompass both skin and wheel well in the groove." -- but this is the way you get the seal around the wheel wells.
The lip of the wheel well and the skin of the trailer both slide into a groove on the extrusion that goes around the wheel well on my trailer. Then a dressing trim attaches to that.
Am I missing something?
Old 09-01-2010, 04:44 PM   #4
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
bryanl,
I've been communicating with Andy on this and he says from 1974 to 2011 has same wheel well mouldings. I need some for my 1967 and Andy says the new type moldings will work with the additional benefit of adding some structural integrity. Any chance you could take a picture of yours so that myself and others can see exactly what they look like. There is an inner and outer.
SilverHoot is offline   Reply With Quote
Old 09-02-2010, 07:55 AM   #5
1975 29' Ambassador
Reno , Nevada
re: "take a picture" ... will do. give me a couple of days.
Old 09-02-2010, 09:54 AM   #6
Some owners install the wheel well moldings that Airstream started using with the 1974 models and up to today.
They are in 2 pieces, an inner and outer molding, for each side.
They are available for single, tandem and tri-axle trailers.
Attached are the photo's.
ID:	109953   Click image for larger version
Old 09-02-2010, 11:12 AM   #7
SilverHoot's Avatar
1967 24' Tradewind
Andy,
How malleable is that trim? My wheel wells look to be a different shape than what you have pictured.
Old 09-02-2010, 11:44 AM   #8
Originally Posted by SilverHoot View Post
Andy,
Those moldings can only go via UPS.
In order to use them, you must cut away some of the side sheet and outer wheel well. That gives the tires more visibility, if you wish.
Old 09-02-2010, 02:32 PM   #9
mwells4654's Avatar
1971 27' Overlander
Antlers , Oklahoma
Hum - do not like the - you must cut away - might keep looking
Mel
Equal-i-zer E2
AIR # 40365
TAC # OK-3
Old 09-02-2010, 03:47 PM   #10
SilverHoot's Avatar
1967 24' Tradewind
Mwells4654,
Kinda what I'm thinking also. Hope to see what others have done. I know VTS sells a J-molding but some have had a problem getting it to make the bend for the fenderwells.
Old 09-02-2010, 04:26 PM   #11
alclad's Avatar
1961 16' Bambi
Wilmington , DE
Images: 46
ok SilverHoot asked inland rv:
Andy,
and as near as i can tell inland rv responded:
Andy,
i, also would like to how malleable is that trim. i figured that it was a mailable item ....
but can you shape it to fit your needs?
alclad is offline   Reply With Quote
Old 09-02-2010, 05:33 PM   #12
1975 29' Ambassador
Reno , Nevada
here's a project to look at - wheel well trim
this trailer has a mismatch between the wheel well and the skin that left quite a gap on the forward end of the wheel well. The skin appears to be aligned with the wheel well towards the rear but drops almost an inch lower in the front. The plan is to trim the outer skin to match the wheel well so the gap in the inner trim will capture both as it appears it is intended to do.
The trim is not malleable, or at least I would not try to do much to it without better metal expertise and the right tools. For me, there is too much cross sectional shape that I would fear breaking. The outer trim is more of a maybe and it is the one that really gets beat up, especially where it wraps under with the bananaskin.
Part of my wheel well gap was due to water pump leaking. That corroded the furnace casing and rotted the floor between the battery compartment and the wheel well. There may have been some impact from frame droop (its a 76 overlander with lots of rough road miles and elephant ears). The curbside is worst but the roadside also appears to have a similar problem. The repair effort started with removing tons of goop tossed in to try to fix the leaks - ugh, hate how some folks try to fix things.
If you don't like the idea of trimming the outside skin, you can always do what the shop manual suggests and add to the wheel well.
Old 09-03-2010, 08:48 AM   #13
Ottawa , ON
Definition of MALLEABLE
1: capable of being extended or shaped by beating with a hammer or by the pressure of rollers
2
a : capable of being altered or controlled by outside forces or influences
b : having a capacity for adaptive change
Mailable: ability to be put into US Post's delivery system
Old 11-03-2010, 08:01 PM   #14
crookedroad's Avatar
2012 25' International
Gloucester , North Carolina
My '72 Safari was missing one of the transition peices (see photo). I got a replacement from Ryan (rvrevive@aol.com) at rvrevive.com, photo also included. He might be able to help you.
ID:	114496   Click image for larger version
crookedroad is offline   Reply With Quote
Free wheel well trim for 310 guy99 Classic Motorhomes 4 04-03-2012 04:48 PM
Wheel Trim mwells4654 General Repair Forum 8 10-07-2009 07:14 PM
Wheel Well Trim (exterior) bevman Clearcoat, Exterior Paint & Trim 6 08-30-2007 09:59 PM
wheel trim fix? cherring On The Road... 10 09-24-2003 01:47 PM
front end vinyl trim, misc trim mlmarch Clearcoat, Exterior Paint & Trim 4 07-07-2003 10:29 AM
