Old 09-23-2017, 09:33 PM   #1
Powell Butte , Oregon
Trident application
Has anybody out there had the trident protection done on there Airstream, we are looking at buying new Airstream, first time buyers, thanks burnsnow
Burnsnow is offline   Reply With Quote
Old 09-23-2017, 10:35 PM   #2
2007 22' International CCD
Trident application
There are many on the forums, myself included, that consider stuff like that to be a major way for a dealer to make a much bigger profit. It is far cheaper to put that money in the bank, along with the cost of a so-called extended warranty, and do your own maintenance, including washing and waxing the Airstream once or twice a year.
It's the same game played by new car dealers, with the same result. They make lots of money, and the fine print keeps them from spending any of it on your issues.
The only vehicles I have ever bought an extended warrant on was our Toyota Prius (two of them) because just the battery pack, if it fails early, is over $8,000. The warranty was only $500 for 10 years and 100,000 miles. Cheap enough.
For an Airstream, not worth it. That's what comp and collision insurance with an agreed value is for.
The clearcoat on a modern airstream is basically permanent, and an expensive dealer wax job is simply not worth the money, IMHO
KE4GNK/AE
'The Silver HamShack' (2007 International 22FB CCD 75th Anniversary model)
Old 09-24-2017, 05:54 PM   #3
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
I agree with rmkrum, save your money....
Troutboy
Troutboy is offline   Reply With Quote
Old 09-24-2017, 06:46 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Rip off like under coating and extended warranties. Give your new beauty a good washing using quality car soap and the occasional hand waxing. Clean road grime and bugs from the front as needed. 5 to 10 years from now everyone will think you just bought a new Airstream.
MICHAEL
Old 09-24-2017, 07:16 PM   #5
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Hugh profit center for dealers. Don't do it. Save the money for things that matter like ice cream.
Old 09-27-2017, 05:30 PM   #6
Trident
Thanksall, kinda figured that was the case, burnsnow
Old 09-27-2017, 06:16 PM   #7
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Properly applied, Trident has value. It is not a wax. Wax boils off in as little as 30 days, depending on the product and number of coats applied. Trident is a nano-tech sealant with an extended life.
Note - it was my understanding that the clearcoat is applied by the material manufacturer. It also is a nano-tech finish with very limited porosity. However, when the sheet is cut for a window or rivet hole, the edge that is created by the cut has no coating and needs to be addressed in some way.
Research the product, the dealer's capability to apply the product, and the alternative surface protection process you are considering. Make the best choice for you.
Good luck. Pat
Trident System Exterior Finish Woosch Cleaning, Stripping & Polishing 13 08-19-2017 11:06 AM
Trident Protection Systems Steamy1 Clearcoat, Exterior Paint & Trim 8 01-26-2015 11:37 AM
Trident Nonotechnology silverwheels General Repair Forum 4 01-08-2015 08:40 PM
Trident coating nbgrossman Clearcoat, Exterior Paint & Trim 1 06-26-2014 05:13 AM
Trident - Clear Coat Sealant Drathaar Exterior Restoration Forum 5 02-14-2012 05:32 AM
