Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 08-26-2009, 02:35 PM   #1
Profile:
Touch Up Clear Coat??
Okay, today's riddle:
I've always been told (10-years of Airstreaming) that you CANNOT "touch up" a little section of clear coat. I've always assumed it was like walking on water to even try it.
So then.......WHY can you buy clear coat spray cans from ALL the normal Air Stream parts and repair places? Huh? Huh? "Splain that to me.
And if I become so bold I actually TRY it, how would I best go about it?
Anniedog is offline   Reply With Quote
Old 08-26-2009, 03:10 PM   #2
StingrayL82's Avatar
Profile:  1971 31' Sovereign
San Angelo , Texas
Images: 37
Annie,
I don't know who told you that but, if you go to Airstream's website, you will find a sheet in the Customer Service area on how to touch up the Plasticoat.
SFC Frederic Lynes
1971 Sovereign International
2004 F-350 King Ranch
EX-WBCCI # 8371
AIR # 8239
StingrayL82 is offline   Reply With Quote
Old 08-26-2009, 06:59 PM   #3
Profile:
Touch up
It was drummed into me for years and years. Every day I was told "don't run with scissors,don't touch the stove and DON'T even THINK about touching up Airstream clear coat!!"
Thank you. I'll go take a look.
Old 09-29-2009, 03:56 PM   #4
Profile:  1999 25' Safari
WINDSOR , ON
touch up
i am also going to touch up my as but not sure what i should us to clean all wax off the surface? i also cannot find the page in airstream's customer service site on how to touch up the plasticoat, if someone could send me the link i would appreciate it. thank you.
garryg is offline   Reply With Quote
Old 09-29-2009, 04:36 PM   #5
Frank&Mike's Avatar
Profile:  1988 32' Excella
Pflugerville , Texas
I think this is the link on the Airstream site where the procedure is located:
Airstream, Inc :: Travel Trailer
Frank&Mike is offline   Reply With Quote
Old 09-29-2009, 10:02 PM   #6
PhiDor's Avatar
Profile:  1994 34' Excella
The Villages , Florida
Thumbs up Repairing the clearcoat
I think any commercial wax remover will work on your trailer. Just don't slobber it all over the place. It might streak.
As far as a new coating, a clear polyurethane spray should work ok. I would mask off and cover any area that does not need touching up. You don't need a professional paint sprayer. A can from the auto supply store or Ace hardware is good. Just follow the directions. PUT ON ONLY A LITTLE AT A TIME! Two or three coats are better than one big blob of sagging poly!
Do this in the shade. Keep your fingers out of it until it dries. Not yet!! Not yet! Next month you can put some wax on it if it needs it.
Not responsible for the outcome.
PhiDor
Phil & Doris Drugge
WBCCI #4941
2006 Dodge 2500 4wd w/Cummins diesel.
Ext. cab, tonneau, and 16.5 mpg towing!
PhiDor is offline   Reply With Quote
Old 09-30-2009, 07:00 PM   #7
PhiDor's Avatar
I notice that Airstream sells a spray can of "Clear RV Acrylic" to make "temporary" repairs. I think I'll buy a can of that next time I have the opportunity and see if what's in the can is simply something sold elsewhere under another name. If it's only for Airstreams, a 'regular size spray can" will probably cost about 50 bucks. After all the touch up paint is $17.00 a can so this stuff which sounds more technical and would be less in demand should be more. Well, maybe only $20.00. I'll call Bates tomorrow and find out.
Phil & Doris Drugge
WBCCI #4941
Old 09-30-2009, 08:41 PM   #8
2airishuman's Avatar
Profile:
Originally Posted by PhiDor View Post
I notice that Airstream sells a spray can of "Clear RV Acrylic" to make "temporary" repairs. I think I'll buy a can...
the o.p. apparently has a 20 year old trailer, and yours is mid 90s?
these trailers did not come with clearcoat.
they came with PLASTI COAT and as stingr' is suggesting THAT is a totally different coating than NEW units.
MANY solvents will completely STRIP plasti coat and some QUICKLY.
so 'just any wax remover' is NOT good advice on the older trailers UNLESS ya wanna strip the old coating.
garryg' is your unit the alcoa finish or the older plasticoat? 99 was ~ the change over from older to newer, extending up to 2000?
DAWN detergent will strip most waxes, if mixed with water and used to wash the area on the OLDER finish.
on NEWER finish (alcoa clear coat) alcohol, 3m wax stripper and other mild solvents may be used, but DAWN will work on these too...
the small consumer 'cans' a/s sells are intended primarily for the new units
AND for touching up the INTERIOR WOOD WORK acrylic varnish.
sure it can be sprayed on the outside, one can use nail polish, any generic auto touch up paint too.
will this look good, last very long, NOT eat the surrounding plasti cote ?
go for it and post results.
there are 100s of threads on this issue, the differences in coating, how to touch up or NOT touch up and so on.
certainly it's your trailer and please do whatever you want, or put whatever suits you on it.
BUT it might be useful to do some basic research into the issues first; stingr' advice is solid on this, as is the link.
IF you've got decent PLASTI COAT the solvents in generic spray paints MIGHT melt or damage the original coating.
for NEW streams the alcoa applied clearcoat is MORE durable and LESS sensitive to common solvents.
so generic spray paints shouldn't harm the coating, but might look like crap too...
i got a fluffy roller and some odd cans of leftover paints, wanna try these too?
free 2 u, just pick a color and pay the postage.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 10-01-2009, 05:07 AM   #9
WINDSOR , ON
touch up
i have the newer coating and bought a can of airstream's acrylic touch up paint $19 "ouch", i just happened to be going by jc. they told me to use alcochol to clean the surface. i sprayed coating into the cap and used an artist's brush, doesn't look any worse or better than before but hopefully prevents any further damage.
Old 09-30-2009, 07:09 PM   #10
PhiDor's Avatar
I just found clear acrylic spray made by Krylon for about 8 bucks a can. As I have a spot or two that needs touch up, I'll get a can tomorrow and let you know how it works out.
Phil & Doris Drugge
WBCCI #4941
Has Any One use microbille on clear coat? Perry Cleaning, Stripping & Polishing 6 12-10-2007 04:42 PM
Clear Coat on Everything! Sherry S Upholstery, Blinds, Walls & Interior Finishes 2 08-07-2007 09:13 PM
66 globetrotter clear coat??? evelitalian 1966 Globetrotter 1 06-21-2007 05:02 PM
Clear coat Damage Resorts Cleaning, Stripping & Polishing 8 06-13-2007 01:09 PM
touch up clear coat... safari05-25 Clearcoat, Exterior Paint & Trim 2 10-22-2006 10:14 AM
