Old 05-23-2006, 02:48 PM   #1
Angel73's Avatar
1975 31' Sovereign
Woodlawn , Tennessee
Images: 65
Send a message via Yahoo to Angel73
to paint or not to paint roof
We're trying to decided weather or not to paint the roof to help control heat and to help seal the roof better....What do you all think?
The Clark Family
Angel73 is offline   Reply With Quote
Old 05-23-2006, 04:36 PM   #2
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Angel, I painted ours white when I painted the trailer, I am not sure if it helps or not, I think it might. It was a lot easier to do than paint the roof as I rolled the top. You can't see it unless you are at higher area looking down on the trailer. Here are some pictures. Marvin
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 05-23-2006, 05:03 PM   #3
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
looks new!
man, what a nice looking coach! It makes me want to paint my A/S cream-colored, with white roof! Serious question: do argosies reflect heat and stay cooler in summer than airstreams? thanks- tim
tphan is offline   Reply With Quote
Old 05-23-2006, 05:04 PM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
I have a 77 soveriegn. I painted the roof five years ago. It is pealing a bit so I am going to redo it. We went to the Internationals in Huntsville once and Rapid city twice. No power for air cond. so we sweated. White roof helps some vs production plasticoat that was pealing and dull. I think it helped about 10 degrees on a 100 F day but difficult to actually measure under controlled circumstances. Which of course you can not control. Seen quite a few people from the west and south doing it. I painted from the awning strip to the end of the roof sheet on the other side and did not paint the ends. You hardly notice it when you walk past the trailer.
Old 05-23-2006, 05:27 PM   #5
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
What's the Best Paint?
I'm convinced that painting the roof white will cut down on solar gain, but I remain unsure of best paint to use and best application process. Suggestions?
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 05-23-2006, 06:35 PM   #6
1979 30' Argosy
Ken.. we used a product called Snow Roof ... available at Ace hardware.. it takes about a gallon to do a 26' trailer... Marvin
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 05-23-2006, 06:38 PM   #7
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Thanks, Marvin. You used a roller, correct? Standard 1/4 inch nap?
Ken L
1966 Tradewind 24
Old 05-23-2006, 07:25 PM   #8
Angel73's Avatar
1975 31' Sovereign
Images: 65
well
The main reason we was thinking about it is that hubby doesn't want to try to polishes the top now that we stripped it.Cause he doesn't want to dent the roof....Plus we normal use just batteries and it does get hot
The Clark Family
Old 05-23-2006, 08:07 PM   #9
1979 30' Argosy
Ken, Yes, did it with a roller, 3 coats. Two would have been enough but the rest would have went bad. It seals the seams and rivets good too.
Marvin & Annie
Niki (fur baby)
WBCCI 10103
Old 05-23-2006, 08:50 PM   #10
lewster's Avatar
Naples, FL , Hood River, OR
Look into products by DICOR. I use their stuff to re-coat EPDM rubber roofs of SOB's that are about to disintegrate. It bonds really well with the existing rubber and might do so with the aluminum as well. Give them a call.
You might also try POR-15. Folks on this forum swear by their stuff as being very durable. I would also seriously consider a self-etching primer applied to theh bare aluminum before applying any type of paint. It will make the paiint last much longer.
Old 05-23-2006, 09:08 PM   #11
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
I have restored 2 sailboats in recent years and getting ready to do the last on again as Katrina totaled the boat. Donít tell me you are sorry as the insurance paid me out and gave the boat back to me. I did want to suggest a paint that I use often and holds up very well in the marine environment and on decks. Look into Interlux Brightside Polyurethane. Brightside lays out like glass.http://www.yachtpaint.com/usa/
Select Paint finishes on the left side.
I also remember that painting the top white lowers the temp by 7 degreees.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 05-23-2006, 09:26 PM   #12
1960 24' Tradewind
santa barbara , California
Hello everyone,
I know inland andy had done some good tests with aluminum panel samples
painting them three different colors and the for one was plain aluminum .I don't know the link,but someone here might or contact andy himself at inland rv.The surprise was that the aluminum plain sample was cooler than even the white one by a small but surprising amount .The plain sample just reflected the heat away better the test revealed .I would check into that before I would paint the roof of your airstream .I myself thought the white would be cooler .
Scott
scottanlily is offline   Reply With Quote
Old 05-23-2006, 09:40 PM   #13
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Thanks, Lew. I'll research DICOR. As for POR-15, I've had extensive, exhaustive, expensive experience with POR-15 in my restoration of Willys CJ2A #75863. http://spongedude.info/cgi-bin/willy...on=view&id=272
I'm not a fan of POR-15 nor would I recommend it. Besides, it will not hold up to UV. Even limited exposure to sunlight destroys it.
Jim Clark, thank for your suggestion re Interlux Brightside Polyurethane. I'll check it out. I've had good luck with exterior finishes designed for marine applications during my previous life before I left the water andreturned to the Land of Enchantment.
Ken L
1966 Tradewind 24
Old 05-24-2006, 05:29 AM   #14
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Got my Interlux paint a couple of weeks ago but the bus and or I have been in a state of constant motion since. Soon I'll slow down and 'get round to it.
As my coach is painted I intend to give it a light scuff with 400 grit and then paint.
Interlux is the best for the as mentioned "sprayed on look" finish.
If you're getting up on the roof just remember to stay on the rivet lines and you should be o.k.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
How to deal with this paint issue? Eaglemate Clearcoat, Exterior Paint & Trim 4 09-13-2011 10:46 AM
Sloped Roof Under Air Horns Johns5711 Land Yacht/Legacy Motorhomes 7 07-27-2011 07:02 PM
Want to paint my roof white.. Bill M. Clearcoat, Exterior Paint & Trim 7 07-23-2011 11:03 PM
