Old 04-04-2009, 09:06 PM   #1
bennyjackmcr's Avatar
2007 25' International CCD FB
phoenix , Arizona
Angry Tape Residue on Clear Coat
I was hoping for some advice on removing some tape residue from the clear coat of my AS. While I was on vacation my neighbor's weed eater kicked some rocks on the side of my AS and broke a window. They taped plastic over the broken window. The window is fixed now but the tape they put on left behind white residue.
Thank you!
Benny Jack - AZ LDZPLIN
2007 25' International CCD FB Ocean Breaze
2008 Toyota Tundra Crew Cab
bennyjackmcr is offline   Reply With Quote
Old 04-04-2009, 09:09 PM   #2
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
It'll be interesting to see what other folks say, but basically what I'd think you'd need is a solvent that will dissolve the tape, but not the clear coat.
My suspicion is that the clear coat has some variety of acetone as a base. If so, it won't be harmed by mineral spirits or rubbing alcohol (or WD40 or creamy peanut butter). And those are the solvents I'd start with.
But, then, that's based on the assumption that the clear coat is acetone based. Let's hear from others.
Lynn
WBCCI 21043
Old 04-04-2009, 09:12 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Old fashioned liquid lighter fluid or Naphtha will disolve almost all adhesives without damaging the clearcoat.
Bria
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 04-04-2009, 09:41 PM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Had the same question and called the factory. They told me to use mineral spirits. It worked great and did not effect the finish.
Old 04-04-2009, 10:39 PM   #5
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
"Goo gone" Home Depot and many other stores.
Old 06-07-2009, 02:29 PM   #6
1984 31' International
Flint , Michigan
Baby oil...works every time
Grandpapa is offline   Reply With Quote
Removing Duct Tape Residue Lumatic Cleaning, Stripping & Polishing 24 01-11-2008 04:03 AM
Clear Coat on Everything! Sherry S Upholstery, Blinds, Walls & Interior Finishes 2 08-07-2007 08:13 PM
touch up clear coat... safari05-25 Clearcoat, Exterior Paint & Trim 2 10-22-2006 09:14 AM
strip clear coat baobi Cleaning, Stripping & Polishing 3 05-28-2006 05:29 PM
Clear Coat/ Plasticoat tmeagle1 Clearcoat, Exterior Paint & Trim 0 08-21-2005 03:37 PM
