View Poll Results: Filiform Corrosion: What would you do?
Use all available options to remove and repair. 3 33.33%
Gently remove and treat, stop the spreading without going overboard. 2 22.22%
I can live with it. 4 44.44%
Voters: 9. You may not vote on this poll
Old 03-08-2015, 01:27 PM   #1
2007 28' Safari SE
Westlake , OH
Tail Light Corrosion
I know this has been discussed, but I would like to get the latest advice/treatment that's out there (plus I don't feel like searching the archives forever). I'd like to replace this tail light bezel housing, or remove and strip it to improve the appearance. I don't mind paying, up to a certain point, to get it done right.
On another note, I have a lot of filiform corrosion to treat on the rivet line and near the marker lights. I have heard that that the aluminum on the marker lights doesn't play nice with the shell aluminum, so wondering if those should be replaced when I do the repair (which I still don't know how I'm going to do but have a good idea).
Thanks for any help you may be able to offer.
ID:	233848   Click image for larger version
TowAir is offline   Reply With Quote
Old 03-08-2015, 01:34 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have tried the spot fix method and not happy with the results. I am going remove my lights and do it properly.
MICHAEL
Old 03-08-2015, 01:37 PM   #3
2007 28' Safari SE
Westlake , OH
How do you plan to do it? I was thinking about trying to buy new lights if it looks like it's going to take 20 hours of work.
Old 03-08-2015, 01:42 PM   #4
AWCHIEF's Avatar
Images: 33
Remove the light housing, strip and clear coat. My time is cheap these days so required time is not a factor.
MICHAEL
Old 03-08-2015, 01:51 PM   #5
paiceman's Avatar
2020 28' Flying Cloud
Upper St Clair , Pennsylvania
Another option is to remove the light housing and have the entire housing painted and clear coated. There is a match for the aluminum color, AS is using it on the exterior covers for hot water heater etc. Also, Vinnies Airstream in CA has a post on his facebook page where he has done the same thing for customers. In pictures it looks nice, and should look good for a long time.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
Old 03-09-2015, 07:16 AM   #6
2007 28' Safari SE
Westlake , OH
Do you the specifics for the paint match? I saw the repair on Vinnie's page, but there was no mention of the color used. Thanks for any help you can offer.
Old 03-10-2015, 07:51 AM   #7
AWCHIEF's Avatar
Images: 33
I have a sneaky feeling that the labor cost of the paint job would exceed the cost of new light housings.
MICHAEL
Old 03-10-2015, 11:57 AM   #8
2007 28' Safari SE
Westlake , OH
The problem is that a new fixture would do the same thing. We are going to powder coat paint it, hoping to get this result:
https://scontent.xx.fbcdn.net/hphoto...a2&oe=55706018
Old 04-02-2015, 09:38 AM   #9
ghatfield's Avatar
2006 19' Safari SE
Anacortes , Washington
No need to clearcoat, at least in AZ
I removed my taillights and removed the tarnished clear coat. Once I got them bright again, I just left them uncoated. No problem thus far. See my previous post on this topic.
http://www.airforums.com/forums/f4/t...bi-127371.html
George
ghatfield is offline   Reply With Quote
Old 04-03-2015, 01:03 PM   #10
2007 28' Safari SE
Westlake , OH
That looks fantastic! Unfortunately for me, the corrosion was very deep into the metal. We're done, I will be putting them back on soon (pics to follow). I am interested in what you used to seal. Apparently it's putty tape across the top and your favorite RV sealant on the sides.
Old 04-03-2015, 05:51 PM   #11
2007 28' Safari SE
Westlake , OH
Here's what we got. Not too bad.
Name:	2015-04-03 17.00.54.jpg
Old 05-04-2015, 06:45 PM   #12
silverbp's Avatar
2014 25' FB Flying Cloud
LaMarque , Texas
I have a new 2014 Flying Cloud less then a year old and I've already got some major corrosion in a number of different locations. I wash it and have waxed it i know four times in the year but it does not seem to help. I was told I should Raise hell with Airstream about this.
Sent from my iPhone using Airstream Forums silver bp
silverbp is offline   Reply With Quote
Old 05-04-2015, 09:16 PM   #13
2014 25' Flying Cloud
Hampton , Virginia
Maybe I missed something doesn't the factory warrant these items, during the first two years?
Chuck
engineshow is offline   Reply With Quote
Old 05-10-2015, 07:37 PM   #14
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
http://www.airforums.com/forums/f142...ml#post1450224
Everything about corrosion with our Airstreams is here in this thread. Spend some time, scan the posts. Repair, prevention, products used--all here.
Howard L. is offline   Reply With Quote
Old 05-10-2015, 08:35 PM   #15
Howard L.'s Avatar
San Antonio , Texas
Name:	ImageUploadedByAirstream Forums1431311412.346747.jpg
ID:	238162Click image for larger version
Name:	ImageUploadedByAirstream Forums1431311491.669085.jpg
This is the best match I can find for repair touch up. As you can see by the spray of the plastic shower door, it's close. I've used it to spray where I've sanded off filiform on the skin. Buy at Home Depot.
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 6 07-03-2018 11:26 AM
Leak near tail light, but it's not the tail light adwriter73 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 03-31-2013 11:34 AM
Aluminum Tail Light Housing Corrosion Shelly M 2006 - 2010 International 15 01-02-2012 11:28 AM
'71 safari tail light/brake light issue TGK Lights - Interior & Exterior 8 08-20-2011 05:45 PM
