We have tried Citristrip, Aircraft Stripper, Cleanstrip, B12 Chemtool and GooGone; even washed off with power washer but to no avail. What else can we try aside from polishing it off?
Try polishing a small patch in the discolored area. If it will polish, it's not clear coat.
If the clear coat fails, the aluminum starts to oxidize and looks like that. The good news is that the reaction is self-limiting and actually forms a coating that protects the aluminum. It should polish off easily.
If you look at the pic you can see the marks where the sticker used to be. The problem is the same as mine sticker goo that wont budge. Any suggestions?
I found many years ago that to remove sticker goo spray WD40 on it and wipe away, the glue transfers to the rag used, past that spray 9 removes the WD40.
