Old 02-02-2010, 10:03 PM   #1
72Blazerod's Avatar
1986 29' Sovereign
Delta , British Columbia
Images: 31
Stripping Clearcoat for Aluminum Mag wheels?
Has anybody stripped the clearcoat off of their mags? If so what did you use? What did you use to clearcoat the bare polished aluminum once it was stripped?
Rod
72Blazerod is offline   Reply With Quote
Old 02-02-2010, 11:38 PM   #2
Rod
Rod.
You can use a good paint stripper for your task.
One of the good brands is Aircraft Stripper. Check with an industrial paint supplier.
Clearcoating the mags can be done 2 ways. The first and chea[est is the clearcoat that Airstream has in spray cans.
The second, is the bulk clearcoat that Airstream has, but it's a 2 part mixture. I don't think is available in anything but gallon cans. You would need the special additive to make the bulk material work correctly.
A few dealers can help you.
You may have a problem if you deal with a US dealer due to shipping flamable materials accross the border, unless you have a friend in the US that you could pick it up from.
Andy Rogozinski
Inland RV Center
Corona, CA
Mothers mag and aluminum? AIR-Quarius Cleaning, Stripping & Polishing 15 09-03-2009 04:37 PM
stripping clearcoat on decals glacierrunne Cleaning, Stripping & Polishing 0 05-27-2006 09:49 PM
Mag Wheels for the AS bigjohn Wheels, Hubs & Bearings 15 10-09-2005 07:30 PM
Refinishing Aluminum Mag Wheels Zettervall Wheels, Hubs & Bearings 9 01-20-2005 10:52 AM
Stripping...Clearcoat that is! InsideOut Cleaning, Stripping & Polishing 19 07-12-2003 07:59 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
