Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Prev Previous Post   Next Post Next
Old 03-24-2003, 03:12 PM   #1
Profile:
Send a message via AIM to Marshall44
Straightening Bent Aluminum Trim
Does anyone have advice about what sort of tool I should use to straighten bent aluminum trim -- for example, I want the "eyelashes" etc. to be perfectly straight before I start polishing. The corner of one is crumpled. Should I use pliers? Or does anyone have experience successfully bending these into shape using something else? Any suggestions are appreciated.
Thank you.
Marshall
Marshall44 is offline   Reply With Quote
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 6 09-08-2009 07:19 PM
Interior Aluminum Replacement swebster Upholstery, Blinds, Walls & Interior Finishes 34 02-24-2005 10:14 PM
Vinyl/plastic Trim Around The Inside Of Windows Tim T Parts Archive 8 10-21-2003 04:02 PM
Door Trim smily Doors & Locks 1 01-03-2003 09:27 PM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 06:49 PM
