Old 02-18-2016, 05:30 AM   #1
2016 27' International
Estero , Florida
Storage - covered or uncovered
We are getting our new airstream in three weeks and while looking for storage down here we have found both uncovered, and covered storage areas.
The prices are way different, but the questions is, is leaving your airstream exposed to the Florida elements while it awaits us to go somewhere bad?
Also, how often does it need to be cleaned?
Thanks everyone!
KariRich is offline   Reply With Quote
Old 02-18-2016, 05:45 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Of course it is bad, UV is your enemy for all of the sealants and the clearcoat. You will have a longer life with less preventative maintenance with covered storage. Aside from the cost, the only downside is solar charging but you can remove the batteries or if you have AC, use a maintainer.
Larry
lsbrodsky is offline   Reply With Quote
Old 02-18-2016, 06:49 AM   #3
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Besides being protected from the rain and sun, with covered storage you'll feel more secure with leaving your fantastic fan vents open. Which will be necessary for air circulation and keeping the humidity down on the inside.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 02-18-2016, 07:09 AM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
Covered storage is always preferable. Especially if your Airstream is going to spend most of its time in storage. If it is affordable for you, you should consider doing it.
Brian
SuEllyn & Brian McCabe
Old 02-18-2016, 07:13 AM   #5
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
If we had an option we would always go covered, but we do not so she sits outside all year, either in storage or on the road.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 02-18-2016, 07:23 AM   #6
Mixter's Avatar
1976 27' Overlander
Covered! Covered! Covered! Unquestionably.
Mixter is offline   Reply With Quote
Old 02-18-2016, 07:37 AM   #7
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The salt air will accelerate corrosion on both steel and aluminum. The moist air will generate mold. So a dehumidifier inside the trailer would be a big help with the mold issue. Spraying the appropriate chemicals around the wheels, jack stand and power cord earth contact areas will hep reduce insect infiltration.
Old 02-18-2016, 08:00 AM   #8
Morgan guy's Avatar
2007 27' Classic FB
Fredericksburg , Texas
We bought our Airstream out of an estate. It appeared to have been left outside for an extended period of time. We did not notice the effect until about a year later when we discovered a soft spot under the dining table. After inspection we found water was coming in around the rear windows because the rubber seal had numerous cracks, apparently from constant exposure to the sun.
The Tex-i-can is Ready to Camp
Morgan guy is offline   Reply With Quote
Old 02-18-2016, 08:33 AM   #9
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Even if I had an SOB I would have covered storage. I keep mine in covered storage but its open. I have a site that is away from the afternoon sun and facing away from the southwest where most thunderstorms bearing hail seem to come from in our area. I have a leak in my rear window that I still haven't been able to find. Waiting for warmer weather to tackle. If it had been in uncovered storage it would be subject to more leaking.
Kelvin
Old 02-18-2016, 08:44 AM   #10
2015 16' Sport
Pineola , North Carolina
We also park under roof. One disadvantage with a new unit is it may take longer to discover a leak. If you have sunny weather when camping one could even be out of warranty. Maybe park it outside during some heavy rain just to be sure.
"Certainty on any matter is not one of the human attitudes the Gods admire or tolerate."
A. Cross
D Greene is offline   Reply With Quote
Old 02-18-2016, 08:54 AM   #11
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
Larry
Yes on covered! Just disconnect the negative terminal on the battery to keep the parasitic load from discharging them.
Old 02-18-2016, 09:10 AM   #12
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Another vote for covered. I am fortunate that mine fits in the garage. I have 30 amp service there too.
BambiTex is offline   Reply With Quote
Old 02-18-2016, 09:24 AM   #13
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
I am storing mine outside, so we'll see how that goes over time. I keep it clean and waxed, and it's not far away so I can keep an eye on it. It has been in very heavy rain, both camping and not camping, and there haven't been any leaks as far as I can tell. I figure they are meant to be outside, and some people are full-timing, which means those units are outside most if not all the time.
SeaLevel is online now   Reply With Quote
Old 02-18-2016, 09:31 AM   #14
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Originally Posted by switz View Post
The salt air will accelerate corrosion on both steel and aluminum. .
If I had a choice between covered next to the ocean or uncovered away from the water I would take the later
Storage: sunny uncovered vs. salt air but covered? Moondoggie Winterizing, Storage, Carports & Covers 3 08-13-2014 05:20 AM
Storage: Covered vs. Uncovered Will_Brule Airstream Lifestyle 19 08-24-2013 08:34 PM
Can't find covered storage in Denver ~ Starting to panic Travel Bird Winterizing, Storage, Carports & Covers 21 10-10-2012 05:15 PM
Covered Storage in Texas? Beer Snob On The Road... 6 12-04-2011 01:36 PM
Is covered storage necessary? GroovePoppa Winterizing, Storage, Carports & Covers 29 05-02-2008 07:03 PM
