Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 09-25-2003, 12:39 PM   #1
Still Working
smily's Avatar
Profile:  North Charleston , South Carolina
Speaking of Stripes and Decals
I am going to replace some stripes on my rig.
I hope that this thread can become a repository for all decals on Airstreams..
For starters, Does anyone know what color or shade of blue is used for a 1979 decal that goes around the trailer. The wide one.
ther is also a silver or grey pinstripe that compliments the big blue stripe.
I am looking for a color close to the rub rails I assume.
I also seen a MH that was in dire need of new woodgrain striping. I wasa wondering what the "official" airstream color or manufacturer number is.
I would like to find a reference that would identify all shades or colors of blue used on Airstreams. (or other colors for that matter)
Smily
smily is offline   Reply With Quote
Old 09-25-2003, 01:19 PM   #2
Profile:
Re: Speaking of Stripes and Decals
That was either mine or Steven Websters (swebster@myrvadvanta)
Sorry, I can't help you with your questions but wish you luck.
Regards,
Jeff
jthew1 is offline   Reply With Quote
Old 09-26-2003, 12:25 PM   #3
Silvertwinky's Avatar
Profile:  South Shore , Kentucky
Our first A/S didn't have a stripe. We thought it would look good to have one so found a sticky tape that had 2 or 3 different colors of blue. We purchased it from a local auto parts store. I stuck it around the trailer completely including the front and was pleased at how well it looked. I may try and find a picture of it and post it later.
Visit our church on the web!
"A safe camper is a Happy Camper"
Bill & Donna
Air Forums Member # 2360
Silvertwinky is offline   Reply With Quote
Old 09-26-2003, 01:14 PM   #4
Ok, here is a picture I came up with after a little cropping. We didn't take as many pictures of the campers back then as I wish now we had. I hope this will be of some help.
Bill & Donna
Old 09-26-2003, 07:25 PM   #5
Profile:
The Continuing Saga
Moved to "Woodgrain Decal Help"
See ya there.
Jeff
Old 10-12-2003, 04:05 AM   #6
Cat
Cat's Avatar
Profile:  Mukilteo , Washington
Images: 8
Send a message via Yahoo to Cat
Decals
With a little searching I found this thread...
I hope it's what you want contributed,,,and I hope I get the feed-back I'm looking for.
I just got my 'rub-rail' VinylClad from Inland RV...all 100 feet of it.
I only needed 66 feet, so I have 34 feet left over.
IF ANYONE WANTS TO BUY THE 34 FEET OF THE 1-1/2 inch Rub-Rail Vinylclad, let me know.
NOW...HERE'S THE REASON FOR MY POST: (and I've attached a photo of this 'mid-section-decal & 2 Vinylclad trims).
Mid-section of the Excella ("Bear"), is a 6-1/2 inch wide decal, which Airstream no longer provides...(RATS)...and above and below that area is a raised trough...with 1/4" inch VinylClad inbetween IN the 'trough' (mine is in perfect condition). The 6-1/2 inch decal in between these 2 trims, is peeling off is an area where it wasn't installed correctly. I'm WONDERING-----
CAN I SAFELY REMOVE THE OLD DECAL...AND JUST EXPOSE THE ALUMINUM UNDER THE DECAL..? & what would I apply over it to protect it (similar to the treatment from the factory="whatzitcalled"?
1. IS THERE ANYTHING THAT CAN BE APPLIED BY THE OWNER TO AN ISOLATED AREA OF THE ALUMINUM LIKE THAT?
2. DOES ANYONE HAVE A SUGGESTION ON HOW TO REMOVE THE OLD DECAL WITHOUT DAMAGING THE ALUMINUM UNDER IT? (Mine is peeling in spots)...but not all over, so I know I'm going to have to remove it with either PRESSURE of a tool, OR, some sort of chemical. ???????
Thanx..
*Cat's Vardo "Bear" (1981-32ft.Excella)
http://autos.groups.yahoo.com/group/RoyalTrailerTrash[/u] to meet good people in good Parks[/i]
Cat is offline   Reply With Quote
Old 10-12-2003, 04:26 AM   #7
Cat
Cat's Avatar
Images: 8
Decal
Darn it...RATS!
I can't upload the photo I really need to show you all. It's apparently too big.
The photo above is a Bear "Look-A-Like"...and the decal on the "Belt-Line" on that one...is solid colour of blue.
Whereas Bear's is multi-stripe and 2 colours of blue, and also a yellow/gold.
I'll try again tomorrow, after I've tried to re-size the photo.
Old 10-12-2003, 04:35 AM   #8
Cat
Cat's Avatar
Images: 8
Try once more tonite
Old 10-29-2003, 08:51 PM   #9
Profile:
Cat I Need the RubRail Vinyl Clad
Hello Cat,
I could use the vinyl clad if you would like to sell it. Also, how difficult was the replacement job?
Best,
JB
Silver Eagle is offline   Reply With Quote
Old 10-29-2003, 10:54 PM   #10
Happycampers's Avatar
Profile:  1979 30' Argosy
Peterborough , winter home Zavalla TX
Talking Easy
Hi.. My hubby and I did ours this past August.. no problem.. but it does shrink.. I know that sounds strange but the sun will make it shorten up.. just leave a little extra on the beltline..ours is a Tradewind. and be sure to put in the rivets so it doesn't come out. We also put a thin line of Parbon.. aluminum colored above both lines .. looks great .. the time is the parbon.. Annie
Happycampers is offline   Reply With Quote
Old 10-30-2003, 06:49 AM   #11
Still Working
smily's Avatar
Tips on removing old decals
Anyone got a easy method for removing decals? (stripes)
I also received my new rubrail last night.
Waited three weeks to receive it and installed it in less than one hour. The whole unit!
I have new decals for the unit and I would like to work on the decals this weekend. My decals look exactly like the image above.
Smily
Old 10-30-2003, 07:11 AM   #12
87MH's Avatar
Profile:  1978 31' Sovereign
Katy , West Planet Houston, Texas
Images: 234
Decal Removal
Short of Thermo Nuclear Devices, most everything has been covered here:
http://www.airforums.com/forum...&threadid=6326
A spray solvent containing Methyl Chloride worked best for me, but it WILL mess with your clear coat.
Watchyagonnado?
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 10-30-2003, 07:55 AM   #13
Still Working
smily's Avatar
Decals in hand
Thanks but I have the decals already. I bought all of the decals for under 150 dollars.
Smily
Old 10-30-2003, 08:16 AM   #14
Astrodokk's Avatar
Profile:  Santa Rosa , California
I know you're thinking decals, but an option would be to paint it after decal removal. The PO of mine painted everything! It looks like original unless someone scrutinizes it closely.
Astrodokk is offline   Reply With Quote
Blue Accent lines boltos Clearcoat, Exterior Paint & Trim 2 03-24-2004 10:41 AM
Decals dienst1 Airstream Motorhome Forums 0 02-27-2003 01:59 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
