Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 09-14-2006, 01:01 PM   #1
KHarris
69 Caravel
KHarris's Avatar
Profile:  1969 18' Caravel
Bayfield , Colorado
Skin Cancer??
Hi everyone,
I am posting a couple of pictures of spots on the skin of our 69 Caravel, hoping someone can help identify these and advise on how to repair them.
Also, the PO spray painted some rivets and screw heads in several places with silver paint...but without the use of any mask. See the photo...what should I do about that one??
Thanks, Krista
Name:	skin cancer.jpg
ID:	25899  Click image for larger version
Name:	spray paint.jpg
KHarris is offline   Reply With Quote
Old 09-14-2006, 05:33 PM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
The first photo looks like something like a tree branch abraded away the clear coat and the aluminum oxidized there. Not sure though...maybe someone else has another idea.
The spray paint can definately be removed with paint stripper...BUT that will also most likely remove the clearcoat too. They were probably painted because they were not aluminum and had started to rust....bummer!
If you are thinking of polishing your trailer, it would probably "fix" both these minor blemihes. But it may not be worth it just to get rid of these "beauty-marks" as it's a big commitment to acheiving the polish and then maintaining it.
If not planning on polishing, I would try a little mild rubbing compound-type of wax to gently try & remove the spray paint without effecting the clearcoat (try on a hidden area first!). Then replace the rivets/screws with aluminum ones.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Old 09-14-2006, 05:38 PM   #3
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
if the clearcoat is in good shape elsewhere, mask out the panel and just strip it and reclear it. If the clearcoat is worn in many spots, I would strip the whole thing. You don't HAVE to polish it afterwards, just a good light shine and seal with product is ok, or reclear the whole trailer if you are up to that task.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 09-15-2006, 08:35 AM   #4
KHarris
69 Caravel
KHarris's Avatar
Bayfield , Colorado
Thanks for both replys. I wasn't even certain the clearcoat was still intact, but it appears to be. I need to look at how much damage there is overall and decide if & when I will tackle the polishing!
Krista
Old 09-15-2006, 08:40 AM   #5
ALANSD
anywhere you apply polish and do not get the "black" stuff on your rag and the surface, it still is clearcoated. That is any easy way to tell. If it starts to get black and then shine, you are stripped in that area.
My Music Site:
Old 09-15-2006, 08:43 AM   #6
Jim Clark
Jim Clark's Avatar
Profile:  2005 25' Safari
New Orleans , Louisiana
Originally Posted by KHarris
Hi everyone,
Thanks, Krista
I would think you could work the paint off with Ultra Fine wet dry and not get into the clear coat if you take your time. Big Eyes, Soap and Water and time.
First Weekend Shindig @ Topsail First Weekend in Jan.
Thanks Jim, N5TJZ
2005 25' Safari ,AIR# 174
S/V Wandering Spirit
http://airstreamlife.ning.com/profile*/JimClark
Picture Gallery
http://gallery.mac.com/jimclark6#gallery
Jim Clark is offline   Reply With Quote
Old 09-24-2006, 09:44 PM   #7
KHarris
69 Caravel
KHarris's Avatar
Bayfield , Colorado
The wet dry sandpaer sounds like a good idea...i'll give it a go. thanks!
Belly skin alternatives? Sneakinup Belly Pans & Banana Wraps 27 04-23-2004 06:33 PM
Floor cancer smily Repairing/Replacing Floor &/or Frame 15 10-13-2003 11:11 AM
Alum. Skin Repair 74Tradewind Ribs, Skins & Rivets 1 06-01-2002 08:08 PM
Under Belly Skin Restoration... Andy R Cleaning, Stripping & Polishing 2 04-08-2002 11:46 AM
Re-attaching cabinets to the interior skin. Andy R Cabinets, Counter Tops & Furnishings 5 04-07-2002 02:54 PM
