What brand & color of paint closely approximates the original silver color used on refrigerator and stove exhaust fan vent covers, LPG regulator and tank mounts etc for early ‘60s?
I used Rust-oleum "professional", aluminum color, "high performance enamel" on my Overlander. The one-quart, oil-based cans were poured into my spraygun for the steel parts (bumper, frame, LPG tanks, etc.) while spray cans (with all their toluene, xylene & acetone) seemed a better choice for plastic parts (AC shroud, fridge vent cover, etc.)
I used the Dupli-Color urethane wheel paint on the stove vent. It comes in a couple of colors to match alloy wheels. I think I used "steel". Good match for the oxidized clear coat.
I wanted something tougher than the Rustoleum enamel since the awning tends to rub on the vent when rolled up. I'll see what it looks like next year, having only made 2 trips since the repaint.
I would like to repaint my emblems and like the looks of each of the examples posted above. Mine have apparently never been removed before since there are no visible rivets. If I wanted to pull them off to bead blast them, how do I get them off without damaging them or the trailer? I tried to slip a plastic putty knife under them to no avail.
...I do have one issue with it that popped up this year, but the issue does not affect fit, form or functionality.
The material used to make up the solar/astro- dome is UV resistant.
The glue used to assemble it is not. It has turned brown.
The gasket material is not UV-resistant resistant either. It was replaced earlier this week (after two years of service) because it drooped, turned light-in-color, and primarily, was turning to dust.
The gasket I can get over. The brown perimeter is a little harder.
