Old 08-29-2007, 02:26 PM   #1
Safari64's Avatar
1964 22' Safari
Eagle River , Alaska
Silver paint for vents & external accessories
What brand & color of paint closely approximates the original silver color used on refrigerator and stove exhaust fan vent covers, LPG regulator and tank mounts etc for early Ď60s?
ie:Exterior accessories.
Andy told us once but I canít find it.
Safari64 is offline   Reply With Quote
Old 08-29-2007, 02:32 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
I used Rustoleum gloss aluminum for ours, it looks pretty good. If it's too shiny, you can try Krylon Aluminum Ingot, a slightly duller silver.
Old 08-29-2007, 03:05 PM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Check my website for pics
I used Rust-oleum "professional", aluminum color, "high performance enamel" on my Overlander. The one-quart, oil-based cans were poured into my spraygun for the steel parts (bumper, frame, LPG tanks, etc.) while spray cans (with all their toluene, xylene & acetone) seemed a better choice for plastic parts (AC shroud, fridge vent cover, etc.)
Tom
Old 08-29-2007, 03:29 PM   #4
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
I used the Dupli-Color urethane wheel paint on the stove vent. It comes in a couple of colors to match alloy wheels. I think I used "steel". Good match for the oxidized clear coat.
I wanted something tougher than the Rustoleum enamel since the awning tends to rub on the vent when rolled up. I'll see what it looks like next year, having only made 2 trips since the repaint.
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 08-30-2007, 12:30 AM   #5
Safari64's Avatar
1964 22' Safari
TomW
you you pleased with the install and appearrance of the VTS astrdome cover?
Old 08-30-2007, 04:33 AM   #6
TomW's Avatar
1967 26' Overlander
My astrodome was marketed by InlandRV, not VTS. I am happy with the amount of light it lets in.
You can read about the install at my website.
I do have one issue with it that popped up this year, but the issue does not affect fit, form or functionality.
Tom
Old 04-02-2008, 09:01 PM   #7
I BEgan's Avatar
Ogden , Utah
Paint on or off of rig?
I would like to repaint my emblems and like the looks of each of the examples posted above. Mine have apparently never been removed before since there are no visible rivets. If I wanted to pull them off to bead blast them, how do I get them off without damaging them or the trailer? I tried to slip a plastic putty knife under them to no avail.
I BEgan is offline   Reply With Quote
Old 04-02-2008, 09:35 PM   #8
I BEgan's Avatar
Ogden , Utah
Found the answer in a previous post:
http://www.airforums.com/forums/f474...val-12506.html
Whenever you find yourself on the side of the majority, it is time to pause and reflect.
-Mark Twain
Old 04-03-2008, 04:00 PM   #9
TomW's Avatar
1967 26' Overlander
I think I will elaborate
Originally Posted by TomW
...I do have one issue with it that popped up this year, but the issue does not affect fit, form or functionality.
The material used to make up the solar/astro- dome is UV resistant.
The glue used to assemble it is not. It has turned brown.
The gasket material is not UV-resistant resistant either. It was replaced earlier this week (after two years of service) because it drooped, turned light-in-color, and primarily, was turning to dust.
The gasket I can get over. The brown perimeter is a little harder.
Tom
Dark grey bottom paint. apple 1 Clearcoat, Exterior Paint & Trim 5 08-07-2009 11:23 AM
Motorhome External Paint Colors wa3vez Clearcoat, Exterior Paint & Trim 0 10-01-2002 02:55 PM
Paint Repair Primer Howard Lefkowitz Clearcoat, Exterior Paint & Trim 2 08-25-2002 11:56 AM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 05:39 PM
Help...re Paint GOOFUP Cat Clearcoat, Exterior Paint & Trim 3 04-18-2002 08:14 PM
